2000 WR400F Fork Oil Capacity?
2 replies to this topic
  • mrlopez
Posted August 14, 2009 - 07:24 AM
Does anyone knows the fork oil capacity for the forks, and what type of oil? thanks
Posted August 14, 2009 - 12:35 PM
The forks are filled to a level, not to an amount. The springs are removed, the main tubes and the dampers compressed, and after the air is removed from the internal dampers, the oil level is set to somewhere between 80-150mm from the top of the inner tube. The standard level is 135mm.
Any good 5wt fork oil works well.
  • Just_a_trail_rider
Posted August 14, 2009 - 05:06 PM
A quart of fork oil will take care of one fork and you'll have a bit left over for the next one.
