Flywheel weight?
17 replies to this topic
  • Chazlom
Posted August 13, 2009 - 04:18 PM
I have a Dr.D 8 oz flywheel from my 03 YZ450F, Will that fit on my Bro's 06 YZ450F??
Thanks,
Chaz
  • DPW
Posted August 13, 2009 - 04:31 PM
No it will not fit...
06-09 ....correct pic posted this time
see the difference?
  • Chazlom
Posted August 13, 2009 - 04:38 PM
Thanks DPW for the quick response! :thumbsup:
Yep, they look different, mine looks exactly like the top picture.
Chaz.
  • Mighty_Whitey
Posted August 13, 2009 - 04:42 PM
Chaz,
If yours looks like the top picture than I'm on my way over! Err, or did you mean the bottom picture?
MW
  • Chazlom
Posted August 13, 2009 - 04:50 PM
Your right, now i'm confused. On the Dr.D site it shows the picture for the 03 thru 05, yet mine looks just like the top picture??
I took this off of my 03... along with a trailtech 10oz and a GYTR 5oz??
Posted August 13, 2009 - 04:52 PM
Sorry guys, the top picture in DPW's post is NOT an '06-9 flywheel. it's the heavier of the two GYT-R wheels for the '03-'05. The newer design has the flywheel "inside out". Yamaha posted the wrong picture on their site.
  • Mighty_Whitey
Posted August 13, 2009 - 05:05 PM
:thumbsup: Thanks Gray, as usual with the in depth knowledge.
Now, do I get the 4.83 or the 9.21oz - Gray, what am I going to notice in difference?
Chaz, I'll order one and come by with a 6 pack next week. That's 4 for me and 2 for you since you'll be doing the wrenching. :-)
http://www.powerpart...r-flywheel.aspx
  • Chazlom
Posted August 13, 2009 - 05:10 PM
Thanks Gray, I was starting to think its not the ring (weight) that makes the difference, but the crank size and shape of the inside of the wheel. (If that makes any since). Anyway it's understood that there is a difference from 05 to 06, and my flywheel won't fit on an 06.
Thanks again,
Chaz
  • DPW
Posted August 13, 2009 - 05:11 PM
I have the GYTR® Off-Road Flywheel # GYT-2S297-50-50 extremely happy with it. I ride MX mostly..sorry for the goof...
  • Mighty_Whitey
Posted August 13, 2009 - 06:21 PM
Thanks for your opinion DPW, so you have the heavier of the two offered by GYTR. I ride mostly MX but was thinking of this for a upcoming trip to Kennedy Meadows. I usually gear very low by adding a tooth in the rear and taking one away on the counter sprocket. That's about 3 total in gearing terms but I really lose the high speed ability during the meadows sections.
Hoping this will give me that tractor-ability down low where I can keep the gearing relatively neutral.
-Doug
Posted August 13, 2009 - 06:54 PM
DPW has the same flywheel I do, and if I'm not mistaken, he rides mostly MX, whereas I ride mostly desert.
IMO, the bike should have been built with this flywheel.
I used the lighter flywheel for a while in my '03, and it was a waste of time. The heavier of the two is definitely the way to go.
  • cowboyona426
Posted August 13, 2009 - 07:00 PM
FWIW I have the heavy "off road" flywheel on my 06 and I didn't notice much of a difference. Some yes, but not near as much as I expected.
Posted August 13, 2009 - 07:28 PM
Where I saw the greatest effect was in how smoothly the engine pulls at lower RPM's now.
  • rexbond007
Posted August 13, 2009 - 07:45 PM
i guess a flywheel weight has no effect with a rekluse,
  • Chazlom
Posted August 13, 2009 - 08:27 PM
On my 03 I ran every conceivable combo possible, hard to imagine. (Check out my garage). I ran the 5oz GYTR, 8oz Dr D, and the 10 oz Trailtech, with and without an auto clutch. I was running an EMF autoclutch back in the day, purchased from Brian Bosch himself.
I ride MX and Desert and with all the mods I found the 10 oz to be the best for my style, it really tamed the power out to make the bike rideable, it would really wear on you during a long Grand Prix. In retrospect I really overdid things.... except the bike was a total hillshooter in Glamis.
With the heavy flywheel and the autoclutch all my buddies called my bike the PW-450. :thumbsup:
  • DPW
Posted August 14, 2009 - 05:46 AM
I agree 100%, very inexpensive and easy mod also.
Posted August 14, 2009 - 06:26 AM
Not true. It still improves the low RPM performance of the engine.
  • cowboyona426
Posted August 14, 2009 - 07:21 AM
I saw some improvement, but not as much as I expected from what I read on here.
