yz426 grey oil
9 replies to this topic
  • 50300
Posted August 13, 2009 - 12:32 PM
I change my oil every ten hours atleast but after my last one only being 5 hours into it i notice my oil turned a greyish colour im woundering why that is,
  • cowboyona426
Posted August 13, 2009 - 12:39 PM
Coolant in the oil, or you sucked up some water somehow.
  • 50300
Posted August 13, 2009 - 12:46 PM
is coolant in the oil bad for the bike if being ridden still?
  • chunk3rs
Posted August 13, 2009 - 01:11 PM
Yes it is.
  • cowboyona426
Posted August 13, 2009 - 01:32 PM
You won't want to ride it anymore until you get it fixed. Could be a head gasket leak, or it could be much worse.
  • mxmaddman
Posted August 13, 2009 - 01:39 PM
You might just have sucked some water into the breather or something. Did you go into deep water? powerwash it and get water in it?
Pressure test the radiator system to be sure.
DONT RIDE IT LIKE THAT
The color is important, as is the texture.
If it's truly grey, and still looks like oil, it may be an indication of a severe wear condition having occurred.
If it's a creamy, foamy beige color, that's either water or coolant. Running coolant in the oil is something like running sand in it, except sand won't dissolve the glue that holds your clutch linings together, or coat all the steel parts with a rusty scum. Water or coolant causes the oil to foam severely into a milkshake texture that has almost no ability to lube anything. Otherwise, there's nothing wrong with it.
  • 50300
Posted August 13, 2009 - 01:56 PM
k well i just had my bottom drain bolt tapped out im thinking it oculd be the metal shavings thats disscoloured my oil?
Posted August 13, 2009 - 02:03 PM
No, that wouldn't do it.
  • 50300
Posted August 13, 2009 - 02:15 PM
well ill jus bring it in and ask aabout it, thank guys
  • Hot  36 replies
  • Hot  50 replies
  • Hot  30 replies
  • 10 replies
