Horn project
8 replies to this topic
  • Vermonter
Posted August 13, 2009 - 04:01 AM
So! I just bought a very clean '04 WR450F that I'll be picking up this weekend.
http://www.uvm.edu/~... WR450F 001.jpg
http://www.uvm.edu/~... WR450F 002.jpg
There's my new baby.
Anyway, I want to install a horn on it. Not just any horn mind you. I want it to sing Dixie when I hit that magic little button.
I'm curious if anyone's tried doing this before, even just wiring up a custom horn to the system (aside from a clown horn).
  • Krannie McKranface
Posted August 13, 2009 - 04:56 AM
The audio you sampled is from an 'italian style air horn' with a sequencer. That would be WAY to large to mount on your WR, as it would require and air compressor. You are going to need an electric horn, which is still huge, and will not program.
http://www.bikerhiwa...rome-p-280.html
http://www.jcwhitney...s/600002599.jcw
  • ncampion
Posted August 13, 2009 - 05:02 PM
Whatever you do, use a relay between the power and the horn as the button will not pass the current needed to properly work any horn.
  • Vermonter
Posted August 14, 2009 - 01:27 PM
Thanks for the replies. It looks like it I want to get this to sound right, I'll have to build my own device. The Wolo horns frankly suck for sound, and the trumpet style horns are too big to put anywhere safely on the WR. If I really wanted to do this I could use one of my old ancient MP3 players and hook it up to a small loudspeaker.
Ideally I'd be able to actually make a small chipset that contained the tone and piped it through a speaker at will, unfortunately I don't have the EE skills to pull that off. One day!
ETA:
Aha! Found something.
http://www.tuxcat.co...y/bikehorn.html I can make a modified version of this with a louder speaker.
Posted August 14, 2009 - 03:48 PM
ETA:
Nah, that won't be near loud enough. A chip that will produce enough power will require a power supply. You need 125db minimum.
I think you should just ride it more and forget about it!
  • Vermonter
Posted August 14, 2009 - 04:55 PM
Very sage advice. :thumbsup: It'll still be a fun side project to tinker with.
  • CORider63
Posted August 14, 2009 - 08:11 PM
I've installed three home-grown dual-sport kits and never had any trouble at all with the horn button not being able to pass enough current for a single horn.
How much current do you think a typical horn draws?
Posted August 15, 2009 - 05:31 AM
You need a relay if you are using an aftermarket horn (or lights, or winch, or whatever) to take the draw off the switch and on to the relay. The stock type horn draws nothing to speak of.
  • 123BigcoopDawg576
Posted August 18, 2009 - 06:41 AM
No relay here...Im running my dual sport kit and HID through the main power switch :thumbsup:
