Yz125 engine noise
7 replies to this topic
  • Cmc681
Posted August 12, 2009 - 07:57 PM
Alright so my '06 Yz125 has this weird noise coming out of the motor. I thought it was something in the clutch and after taking apart and inspecting many times I have come to the conclusion that the clutch isn't it. It's really an indescribable noise, not a grinding, pinging, scratching or anything like that. The bike will be running, not in gear and sound fine then the noise will start and either just go away for a minute or go away when I put it in gear. The bike also rides fine it just makes the noise when not in gear. I am going to try to take it to the shop tomorrow but I was just wondering if anyone has had this problem. Thanks.
  • RBYM
Posted August 12, 2009 - 11:21 PM
My 06 YZ125 makes a whining noise in neutral and only neutral, it is almost undetectable though and it is brand new also. I think it is normal.
  • MOTOPHILE
Posted August 13, 2009 - 10:49 AM
Could be the main bearings about to go, and only make a noise (so far) while under a load...
  • scooter042
Posted August 13, 2009 - 08:15 PM
Is it a rumbling whirring noise with a bit of diesel motor sound? If it is just go ride. All my 2 strokes have had that noise until I pull in the clutch or put it in gear.
YAY! 100 posts...
booo. not half full. wanted to be at half tank by now. ...must...try... harder.
  • Cmc681
Posted August 13, 2009 - 08:33 PM
Would the noise go on and off? Because now that I think of it it is a kind of like that.
  • scooter042
Posted August 13, 2009 - 08:38 PM
It could go on and off. Does it get quieter when the clutch is pulled in?
How many hours on it and when was the last oil change?
  • RBYM
Posted August 14, 2009 - 12:43 AM
YAY! 100 posts...
Same here! :thumbsup:
  • Cmc681
Posted August 17, 2009 - 08:10 PM
No the noise doesn't change with the clutch or rpm's. I took it to the shop and the tech didn't know exactly what it was. I am going to split the cases to inspect since that's the only thing I can do.
Squish or #8 slide? by yz dude
  • Hot  27 replies
3 points of Spooge by CaptainKnobby
  • Hot  60 replies
Yz250 woods questions by XRalways
  • Hot  48 replies
Hero Dirt in the High Desert by 2strokeYardSale
How low can a dirt bike be lowered? by Numsa Hul
  • 11 replies
