Electric start help
6 replies to this topic
  • pobenda
Posted August 09, 2009 - 09:23 PM
I have a wr450 2006 and my electric start sounds weak. I thought it was the battery so I bought a new battery and it still sounds weak. When i press the button it sounds like the battery is weak but it still starts the engine. I can do this all day and it won't drain the battery but just sounds weak. Is this a sign of the starter going bad?
  • Butta
Posted August 10, 2009 - 07:15 PM
Try cleaning the connections at the battery and the starter.....maybe there's some corrosion. Otherwise, check the operation of the decomp system, maybe it's a little higher compression during start?
  • pobenda
Posted August 10, 2009 - 07:36 PM
How do you check that? I'm not familiar with it.
  • ww44wrf450f
Posted August 11, 2009 - 09:48 AM
It might be time to also check your valves.
  • CanadianWR450
Posted August 12, 2009 - 04:44 PM
mine did the exact same thing, until it finally died...acted just like a dead battery, but it was the starter itself...it needed a rebuild badly...took it apart and the brushes etc were toast...I bought a new one instead of rebuilding it
  • pobenda
Posted August 12, 2009 - 05:56 PM
Is it easy to rebuild?
  • CanadianWR450
Posted August 13, 2009 - 02:00 AM
I don't think it would be too bad. I have a funny feeling though once you price out the parts, you may not be saving a lot....
check your manual, and compare rebuild part prices to buying the full starter.
I'm going to keep my old one as a spare. If the new one ever dies, I can rebuild the old one, and still be able to ride while I do it. You can't ride the bike with the starter out of it
