2003-05 YZF 450 Exhaust Cam Q?
18 replies to this topic
  • MXR176
Posted August 09, 2009 - 06:37 PM
HAs anyone tried the 2003-05 Cam in the 2009? The last Yamaha 450 I owned was the 2003. It came off the bottom and pulled good all the through the RPM. I had the motor done on that and full exhaust etc etc. I then went to Honda's from 05-08 and had motors everything on them and those motors were awesome I mean unbelievable. I then had an offer to go back to the Yamaha shop that I used to ride for. I just went and picked up a 2009 and have already had the motor done, exhaust, U4.2, HC piston, ENZO suspension etc etc. I love the smooth power but its lacking the bottom to mid that the honda's had and the bottom through top that the 03 had. Opinions appreciated. :thumbsup:
  • MXR176
Posted August 10, 2009 - 07:13 AM
Neone????????????
Posted August 10, 2009 - 08:43 AM
Why does that surprise you?
  • MXR176
Posted August 10, 2009 - 10:44 AM
What surprise me? Im trying to see if anyone has ran or tried the 03-06 cam in the 08 or 09 and what they thought of it. Did it boost the bottom back up?
  • TIG88
Posted August 10, 2009 - 11:19 AM
From what I understand, the bottom end pull on the 03-04 had more to do with ignition timing than anything else. Maybe you should try a variable ignition box. I forget who makes it (I'm sure someone will chime in), but it has like 10 different settings.
  • mikedabike
Posted August 10, 2009 - 11:48 AM
What do you mean by had the motors done? Done what. I have a set of cams from a 04 that I might try in my 07 if I get a chance. I will report back when I get around to it.
Posted August 10, 2009 - 11:52 AM
Vortex has one. There are others.
The recommended fix for this if a good exhaust won't do it is the '06 exhaust cam (5TA-12180-10-00), not the '03-05 (5TA-12180-00-00). Using the 5TA--00 may work, but might cut off too much top end.
Even with the restrictive stock exhaust, the '09 has 4 hp more than the '03 at the power peak. Virtually any decent exhaust adds 5 or more hp at the 5000 rpm zone of the middle range and wakes the bike right up. Absent the pipe, you'd gain some from the earlier cam, but not as much as with it.
  • MXR176
Posted August 10, 2009 - 12:44 PM
I have a Vortex deal through MTracing.com but a exhaust cam is still cheaper then what I can get one of those even at my cost.
  • MXR176
Posted August 10, 2009 - 12:45 PM
I have the full Yosh RS2 system Ti/Ti.
  • MXR176
Posted August 10, 2009 - 12:47 PM
Ported polisted flowed, cams, ignition, carb work, HC piston, lightened crank, big valved head etc etc.
  • Geoffit
Posted August 11, 2009 - 01:06 PM
The cams in all the 03 to present yz450 are very much the same as far as the lift and duration. what is not the same on these motors is the cam timing ( the position the sprockets are pressed on) in common terms this would be the lobe centers. The new motors have these numbers on the order of 5 degrees different on the exhaust and 7 on the intake. The cams can be retimed but this takes a fair amount of skill and knowledge. If you want a hit more like the early bikes and the top end change both cams just the exhaust won't do the job.
Posted August 11, 2009 - 02:04 PM
If you change both the intake and the exhaust you will increase the low end at the expense of the top. Regardless of what you may think, remember, imagine, or believe, the '03 and '04 models do not have the same high rpm power or rev past 9500 rpm with the same verve that the '06 does, much less the '07 or later models.
Changing out the exhaust cam alone has been tried, and does work. In fact, the only difference between the '03-'05 YZF and the '03-'06 WR450 was the exhaust cam; the intakes are the the same. That's a little bit of an indirect reference, but it's an example of the fact that the lobe centering of the two cams need not be kept in sync with each other.
The thing that clouds the issue here is that the OP now informs us the bike has had engine mods including "cams". The brand, grind and timing are unknown, so in this case, the question of what to do is much more open than with a stock '08-'09. A pair of '06 cams might be the best approach.
  • Geoffit
Posted August 11, 2009 - 03:31 PM
I agree that the cam lobe centers are not related as such. I have a drawer full of stock cams from all the yfz and yz models ( I love E-BAY) and except for the lobe centers they are the same. I have changed the stock timing on 4 08 motors and the difference on a supermoto track is night and day. I would bet though that on a slippery MX track the lap times would be slower.
Posted August 11, 2009 - 04:03 PM
You are probably correct about the disadvantage of too much grunt. It's often more thrilling than useful. I recall that each year YZF beginning with the '06 was criticized for having too little low end power in the shootouts, and yet the YZF was frequently the bike that turned in the lowest lap times. I guess no one saw the connection.
What you should try, if you have not, is a cam set with offset lobe centers, i.e., an '06 exhaust with an '07 or '08 intake. Could be the ticket.
  • MXR176
Posted August 11, 2009 - 06:03 PM
Ok thanks for the info! The 07, 08, and 09 all have the same intake cam if Im not mistaken right? So what I need is a 06 Exhaust cam then right?
Posted August 11, 2009 - 09:41 PM
Nope. The intake cams are different in each of the '03-'05, '06, '07, and '08-'09 models, each timed with progressively more bias to high end power over low end.
As to what you need, I don't think any of us can say that without knowing which cams are in your bike now.
  • MXR176
Posted August 12, 2009 - 05:06 AM
My bad I thought I posted I still had the stock 09 cams in it. My bad for leaving out that info. Hope that helps now. :thumbsup:
Posted August 12, 2009 - 08:06 AM
Quite the opposite. You posted:
If you have the '09 cams, then start with the '06 exhaust cam. I assume you have an aftermarket pipe already?
  • MXR176
Posted August 12, 2009 - 09:02 AM
Ok let me clarify everything. My 2009 YZF 450 has the head ported polished and flowed, Full Yosh Ti exhaust, stock cams and piston. The motors that I was talking about that had the full works with the igniton, cam, lightened crank etc etc. Were my honda's and my 2003 Yamah 450.
  • 5 replies
  • On January 15, 2017
  • Hot  38 replies
  • Hot  30 replies
