suspension settings on yz450f 2005 model
3 replies to this topic
  • robbo74
Posted August 09, 2009 - 02:26 AM
Hi guys after some info on setting up suspension on my yz450f im riding on pretty compacted clay and the local guys have built some pretty decent jumps out there my bike seems to kick the arse end up when i leave the jump dont know if its me or the bike any info would be much appreciated.:thumbsup:
  • usmcpaul
Posted August 09, 2009 - 05:50 AM
What have you done to your setup? Springs, re-valve, fluid, sag.....?
How much do you weigh?
Posted August 09, 2009 - 08:53 AM
1) All four-strokes will kick the rear more than two-strokes do if you leave the jump crest with the power off, or drop the throttle sharply as you leave the top. They will tend to kick over bumps with the throttle off, as well. This is a simple response to all the extra engine braking, and you'll have to learn to finesse the throttle just a little.
2) YZF's have too little initial rebound response as a general rule. Restacking the valve is the correct cure, but you can help the matter some by cranking the rebound clicker down some.
  • robbo74
Posted August 09, 2009 - 01:27 PM
Hi there so you are saying to make the rebound harder with the clickers thanks robbo74
Hi there so you are saying to make the rebound harder with the clickers to stop some of the kick, have always ridden 2 strokes first 4 stroke i have owned bit of a newbie to 4 strokes thanks robbo74.
