Tell me everything you know about the Suzuki DR 125
Posted 06 February 2010 - 08:15 PM
All of the KX shocks I looked at had reservoirs - not sure how that would work.
It looks as though there isn't a way to get the spring off the shock, because I was pondering whether I could measure it and just get a new spring if the shock isn't leaking...
Posted 08 February 2010 - 09:05 AM
The spring may come out by unscrewing the small end of the shock. Look at the parts diagram to be certain. If that's the case, they're often a royal pain, but do come apart.
Posted 12 April 2010 - 07:21 AM
Also found out I'm running a #100 main, which seems kinda small, but according to the parts diagram, is stock.
Posted 29 December 2010 - 08:01 AM
First, I am new to posting so I apologize if this messes up.
Second, thanks for posting all of your discoveries and photos, professor.
Third, if you don't mind sharing just a few more pointers, I recently scored a 2006 DRZ125 complete exhaust on flebay and intend to do the same switch you did in November to my 1994 DR125SEL. My son only uses it for trails and its generally a good bike but as you know it's underpowered for its weight.
(kept front & rear lights but stripped mirrors, turn signals & luggage frame. Prev. owner installed tidy little UFO rear fender/light but I had to wire it.). I'm not going to go crazy trying to make it something that it isn't, but I hope that less weight and any added boost from the new pipe will help. (Lighter used wheels would be cool... the steel ones sure are hefty.) Anyway,
Did you make any carb adjustments after the pipe switch?
Past routine maintenance and pipe swap, any other advice on tuning it for best output (short of top-end swaps / big projects)?
Link to photo: http://www.bikepics....ctures/1024781/
Smacaroni said:
Almost a perfect fit. Install the silencer before tightening down the head bolts, or you'll never get it on. There's one hole in the middle of the pipe that you probably should drill one to match the frame, I didn't though, I think it will be fine. Takes about 15 minutes to install.
The modern piece is so much lighter, probably 1/2 the weight of the stock DR piece.
Sounds like a DR-Z125, although there's a tiny metallic under tone to it. But it looks natural. Before:
After:
Posted 31 December 2010 - 05:33 AM
No big plans for the DR125, it was just a beater buddy bike and I think that's what it's current owner planned to do with it after I sold it to him.
Best bang for the buck power wise, at least from what my experience with our DR-Z125 is a SP200 motor complete swap.
Check out this thread: http://www.thumperta...885#post9734885
Posted 20 October 2011 - 05:16 PM
Posted 21 October 2011 - 03:56 AM
Jetting changes suggested would be similar, but not exactly the same since the DR uses a 20? mm carb vs. the 22? mm the DR-Z uses.
And I see my server at home has taken a dump again. If you want photos, I'll upload them somewhere else.
Posted 21 October 2011 - 07:37 AM
I just picked this thing up yesterday, not too much stuff about these things. Do you know of a place that has any specification type information??
I willl make a thread and try to get some pics of the old dog.
Posted 25 February 2012 - 03:50 PM
i bought the bike non running for like 200 bucks, got it running (very, very roughly) and with gas climbing like it is i want to throw it on the road as an a commuter
bike only starts when you block off intake of carb with your hand, then kick it over with your hand in place (acting as a choke) obv needs to be fixed
and then, once its running, no matter how hot or cold it is, if you rev it up past like 1/2 throttle, after releasing the throttle it backfires, every time, without fail
any fixes? ill start making it fast once it runs decently x)
thanks guys!
Posted 27 February 2012 - 05:38 AM
Couldn't find anything on the 86, but here's the 87: http://www.suzukicyc..._sales4_900.jpg
Posted 28 February 2012 - 07:33 AM
Edited by Smacaroni, 28 February 2012 - 07:34 AM.
Posted 28 February 2012 - 08:07 PM
Internals? Timing? Rings?
8500 on the bike if what looks to be rough riding,
How much is a used drz carb do you think?
Posted 29 February 2012 - 05:36 AM
There's new ones listed on ebay for $80, but they look like they might be Chinese imitations. There's a used KLX125 carb on ebay for $90.
Everything but the transmission on your motor can be replaced with DR-Z125 parts. The DR-Z has a 5spd transmission, I'm pretty sure the DR/SP125 are six speed. Keep this in mind if you need to replace anything.
Edited by Smacaroni, 29 February 2012 - 05:38 AM.
Posted 02 March 2012 - 11:43 PM
The carb, that's a different story, its been rebuilt a couple times, but I need new jets for it, one if the jets is semi clogged with something I can't bore out
I swear the carb is the biggest issue, when it was running, none of the screws seemed to change a thing. And, something I just noticed today, was that at dead center with the handle bars, the front wheel turns right? Its that a, set of bent forks, or can that be adjusted
And I believe the 2 air boxes from sp to dr are different, I have 2 sitting side by side, and One certainly doesnt fit
Posted 05 March 2012 - 07:31 AM
Posted 21 May 2013 - 09:15 AM
I'm Portuguese and I have a 1982 Suzuki DR 125S (SZ Model). When I bought it, the only mods it had were a bored cylinder (62mm diameter), a piston from an honda bike (I was unable to discover the model, I just know it was a 4 valve model and a 15mm gudgeon pin) and a new (stronger???) conrod matching the 15mm gudgeon pin. But now the piston oil ring just "glued" to the piston and the bike was burning the oil. The piston was wasted. Now I had the cylinder bored again (63mm), but I couldn't find another piston to replace the one I had, so I bought a custom made one. This problem is solved. But now I have another problem. The rear shock of my bike is blown and I need another shock absorber. But suzuki just don't sell those anymore, so I need to discover another rear shock to replace the one I have. Do you know if there is another motorcycle model I can get the shock absorver to replace mine? A cheap one if it's possible?
Regards.
Follow us:
