Need A Answer Fast!!!
3 replies to this topic
  • gordster1122
Posted August 07, 2009 - 09:34 AM
i have my 426 almost apart and i cant get the swingarm bolt out so i can get the engine out and someone on here said use a brass punch will these because i want to get it apart so i can get the frame powdercoated and put back together http://www.princessa...yword=punch set
  • gordster1122
Posted August 07, 2009 - 10:30 AM
k got it out now my other question is near the bottom where it is bolted to the frame i try and its on so tight would it be better just to use a impact gun to take it off and the where the engine bolts on 2 on the bottom can i use a impact to get the bolt out of there 2?
  • matt4x4
Posted August 07, 2009 - 10:44 AM
yes you can - and even if you break the bolts, you can just replace them. Tried heat and penetrating oil on the threads yet?
  • gordster1122
Posted August 08, 2009 - 04:58 AM
no i havent i was trying to take the bottom bolt out and heard a crack think i broke it how would i get it out now and where can i get new bolts for them ?
i was looking on
