smokes like crazy with the choke off!
6 replies to this topic
  • tiparosa
Posted August 02, 2009 - 07:21 AM
Purchased a 2000 YZF426 from a buddy with low hours and sat for a while with little use. Took it to a local dirt bike shop and they changed fluids and got it running. Just got it and when it starts with choke on all is fine with high idle and when you turn off the choke it smokes like crazy and does not idle. Any advise?
  • mjw1
Posted August 02, 2009 - 08:54 AM
You need to clean the carb the pilot jet is probably clogged.
Posted August 02, 2009 - 09:29 AM
What color is the smoke?
The carb has two knobs on the side, one red, one black. Which one are you calling the choke?
The black knob is the choke, the red is the hot start air bleed. They do the exact opposite of each other. Be sure you aren't pulling both out and then pushing in only the hot start, leaving the choke on.
Watch:
http://www.yamaha-mo...troke_vid_a.mpg
http://www.yamaha-mo...troke_vid_b.mpg
  • tiparosa
Posted August 06, 2009 - 07:54 PM
I am using the right buttons (black for cold engine). Once started and off choke I roke briefly around my street and it smoked like a freight train. The cycle shop told me, and charged me, that they cleaned/rebuilt the carb.
Any advise on which direction to go?
Posted August 06, 2009 - 08:20 PM
I'll ask you again, what color is the smoke?
  • tiparosa
Posted August 09, 2009 - 06:16 PM
blue smoke, oily. Will only idal with choke on.
Posted August 09, 2009 - 07:44 PM
The choke only situation is likely the result of a varnish blocked pilot jet.
When you started it, did you add oil first?
  • 10 replies
  • Hot  47 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
