bulb type
16 replies to this topic
  • desert-rat660
Posted July 31, 2009 - 04:49 PM
what type of headlight bulb is in an 07 wr450?
  • 123BigcoopDawg576
Posted July 31, 2009 - 05:40 PM
H6M :thumbsup:
And if your asking then you might want to look at this as well
http://www.thumperta...ighlight=07 hid
  • desert-rat660
Posted July 31, 2009 - 05:47 PM
thanks man
  • desert-rat660
Posted July 31, 2009 - 05:51 PM
what ballast is that?
  • 123BigcoopDawg576
Posted July 31, 2009 - 06:11 PM
Here is a link to the bulb. Order a 4300K range bulb (fyi this is for two bulbs)
http://cgi.ebay.com/...sQ5fAccessories
Here is a link to the ballast (fyi this is for two ballasts)
Both items have free shipping so your looking at 79 bucks for two setups...sell the other setup to a friend or fellow TT'r :thumbsup:
*** Read the Ebay listings carefully as I only searched for what you needed :worthy:
  • Sasquatch2112
Posted August 03, 2009 - 02:41 PM
123BigcoopDawg nice job on the HID setup. 2 questions;
1. Could you put a(n on/off) switch right before the ballast?
2. What type of regulator would be needed for the ebay setup you have above?
Thanks
  • Yamaha_James
Posted August 03, 2009 - 03:27 PM
Thanks
Yes, what you would need is a switch that meets(and exceeds a little to be safe) the volt/amp/wattage of the light, you could put it anywhere running on the wire feeding electricity to the light, just make sure you switch (and wire if you added some) are of appropriate power rating. :thumbsup:
  • 123BigcoopDawg576
Posted August 03, 2009 - 03:31 PM
Yes, you would want to put a switch...
At a minimum, you would want to float the ground on your stock stator and then get a regulator/rectifier
Check out these threads for more info
http://www.thumperta...ad.php?t=721647
http://www.thumperta...ad.php?t=438469
  • Sasquatch2112
Posted August 18, 2009 - 10:19 PM
Thanks for the help 123Bigcoop, I got the HID running, with a Trail Tech stator.
I ran the light through a switch, then through a 10amp fuse, then straight to the battery.
Two Questions;
1. do i need a relay?
2. is a 10amp fuse too high? Should I use a 5amp?
Thanks.
  • 123BigcoopDawg576
Posted August 19, 2009 - 06:02 AM
Two Questions;
Thanks.
1) Nope
2) 10 amp is fine.
Question...why did you buy a trail tech stator?
  • Sasquatch2112
Posted August 19, 2009 - 10:32 AM
cause i want to add a second, and possibly third light, and hard-wire my GPS. I didnt feel comfortable tinkering with my stock stator.
  • 123BigcoopDawg576
Posted August 19, 2009 - 10:44 AM
you made the right decision then! now post up some pictures of the install :thumbsup:
  • blackdog9
Posted March 01, 2010 - 05:46 PM
OK....NEED SOME HELP HERE. HAVE YOUR SAME BIKE, BUT I USE IT TO RUN DAKAR AND BAJA LIKE RAIDS. FOR THAT PURPOSE ITS EQUIPPED WITH A GPS, AN ELECTRICAL POWERED ROAD-BOOK HOLDER, AND TWO ICO ODOMETERS, OF COURSE ALL OF THEM POWERED FROM THE BIKES ELECTRIC SYSTEM.
ELECTRIC SETUP IS STOCK, AND IN THE LAST YEAR I HAVE HAD THE RECTIFIER REGULATOR UNIT REPLACED TWICE :thumbsup: , BECAUSE IT FAILED ; DETECTED BECAUSE OF HEADLIGHT BURNING.
NOW I`M IN THE SAME SITUATION, SO FOR YOU ELECTRIC YUNKIES :ride: IS THE QUESTION....WHAT IS NEEDED TO CHANGE: AN AFTERMARKET STATOR, A NEW STOCK RR, OR TO CHANGE BOTH...ANY BRANDS SUGGESTED?
THANKS A LOT.
SERGIO RAMOS
  • 123BigcoopDawg576
Posted March 01, 2010 - 07:21 PM
Sergio
With all the stuff your running the one and only stator I would recommend for you would be the TrailTech. Here is my review on all of the major aftermarket stators for the WR.
  • blackdog9
Posted March 02, 2010 - 05:30 AM
sergio
with all the stuff your running the one and only stator i would recommend for you would be the trailtech. Here is my review on all of the major aftermarket stators for the wr.
thanks a lot dear fellow... One more q, would it be needed to chnage the rr or can i run the stock one with the tt stator??
Thanks
  • 123BigcoopDawg576
Posted March 02, 2010 - 07:02 AM
One more question, would it be needed to change the reg/rec or can i run the stock one with the Trail Tech stator??
You will want to replace the reg/rec as the stock one is AC only.
When you swap stators, you will be converting the bike to DC only.
You can buy the trail tech setup and it will come with the right reg/rec
Check out this link: http://www.trailtech.net/S-8502.html
  • blackdog9
Posted March 02, 2010 - 09:39 AM
THANKS A LOT..:thumbsup:..I WILL BE ORDERING THE KIT A.S.A.P.
SERGIO
