michelin desert rear
1 reply to this topic
  • irondude
Posted March 28, 2003 - 06:28 PM
Time to bust out of my Dunlop routine. I've never tried the Michelin Desert. In the catalogue there are three models of 140/80/18's -- 54R, 72R, 74R. What the differences are? Compound? Would the 72R be their IT? Which one do I want for high speed desert with rocky technical?
Thanks BRPigsters.
  • needsprayer
Posted March 29, 2003 - 09:57 AM
HOW TIRE SIZES ARE MEASURED.
Sample tire size of 100/90-19 (57H)
1) 100 Cross-section width in millimeters
2) 90 Aspect ratio, i.e. the ratio of the tire's height (H) to its width (S), expressed as a percentage (H÷S)
3)19 Rim diameter, in inches (Ø)
4)57 Load index
5)H Speed rating
Speed Rating - maximum speed
Code mph km/h
R 106 170
Load Index indicates the maximum load at which a tire can be safely operated .
Load Index for the codes you specified:
Code lb kg
52 441 200
72 783 355
74 827 375
So the R series is high speed
The actual load depends on you total weight and the geometry of the bike (Front vs Rear load distribution).
The BAJA rear tire is just as good as the Desert rear tire and costs less. I have the Desert tire up front (like the tread pattern better than the BAJA) and the BAJA in the rear. They wear very well. I like the handling in Desert conditions, great in the sand. Braking on asphalt requires steady pressure and panic braking is not advised.
  • 4 replies
  • Hot  29 replies
  • Hot  35 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 9 replies
