YZ 400F jetting, cant seem to get it right
7 replies to this topic
  • rmx250rider
Posted July 31, 2009 - 02:21 PM
I had no help in the jetting form...
I ran stock 175 Main Jet, and backfired coming out of high rpm's
So I stuck a 178 Main Jet, got the same result.
I have the fmf powercore with 450 airbox(dont know if the 450 airbox is bigger then the 400) just cleaned the acc. pump
should I mess with the fuel/air mixture screw?
I just dont know what to do with it anymore
  • Aaron_YZ450F
Posted July 31, 2009 - 02:30 PM
What year is the bike, what elevations and temps are you riding at?
  • rmx250rider
Posted July 31, 2009 - 02:43 PM
it is a 1998, riding between yadkinville and steel creek...
temp betwwen 75 to 90( 95 is the highest I rode in)
run 93 octane
  • Aaron_YZ450F
Posted July 31, 2009 - 03:00 PM
How bad is the popping, Is it only on decel or constant and excessive. What is the Elevation? A certain amount of popping with these bikes is normal, if it is excessive I would start with your pilot jet and not the main. the fuel screw should be your next step after that. I had the same problem and will post the link below to my thread and also Here is a great technique from Eddie Sisneros that got my bike running like a clock....until I cracked the case (another story).:thumbsup: Go back to the stock main and try this brother.
http://www.thumperta...ad.php?t=327405 Eddie's Sticky
http://www.thumperta...3134&highlight= My post
  • Aaron_YZ450F
Posted July 31, 2009 - 03:06 PM
Also for the fuel screw adjustments, if you want to make life a little easier on yourself, spend 12 bucks and get a Tusk Fuel Mixture Screw-$11.99 (It's a dial, with numbers that sticks out so its easier to make the fuel screw adjustments and keep track of # of turns) Best of luck to ya man.:thumbsup:
Posted July 31, 2009 - 03:22 PM
The main jet has nothing to do with exhaust backfire on deceleration:
http://www.thumperta...599#post3710599
Confirm that you do not have an air leak in the exhaust system, then visit the jetting DB and find what others with similar setups are using for a starting point, and read this:
http://www.thumperta...699#post2881699
...and this:
  • rmx250rider
Posted July 31, 2009 - 03:35 PM
how to I access the piolt jet?
Posted July 31, 2009 - 06:00 PM
It's forward of the main jet in the bottom of the carb. On a 400, you should be able to rotate the loosened carb far enough for access. Before you do that, try the pilot adjustment as outlined in the third link I posted. There may be no reason to change it.
Download a manual here:
http://www.yamahaown...ook.com.au/?r=0
If you you can't get the link to work, let me know here.
Motocross
  • Hot  491 replies
  • 0 replies
  • On January 15, 2017
  • 9 replies
