Piston preference?
6 replies to this topic
  • CanadianWR450
Posted July 28, 2009 - 01:14 PM
Anyone have any views as to piston preference?
Any ones better then others in performance/price?
Wisco vs OEM as a example. Any to avoid?
While I'm here, although I have searched the crap out of this, there does not seem to be any draw back to having your cylinder re coated / bored by a reputable shop, vs buying a new one from Yamaha, correct?
  • Hempstead
Posted July 28, 2009 - 01:20 PM
Wiesco and pro-x have always been good in my book good quality.
You could go for a slightly higher compression so that you'll still be able to use pumpgas but get some performance gains.
If you stick with you current cylinder id go with a pro-x with a very slightly larger bore. In most situations id go for a bore/replate, this is much chepaer than buying a fresh cylinder from yamaha.
  • 123BigcoopDawg576
Posted July 28, 2009 - 05:01 PM
OEM all the way! :thumbsup:
  • CanadianWR450
Posted July 29, 2009 - 12:39 PM
NORMALLY I'm all over getting all the performance, but honestly, not needed here. I'm 40, and this is my first off road bike really, picked it up last year.
It's a 04 Canadian model, Air box cut outs, etc, with JD Jetting, Hotcams, and a FMF PowerCore Ti, and honestly, I do not think I'll EVER need more power then the thing has now. It hits hard, and fast, and just keeps pulling.....:thumbsup:
I'll probably go OEM Piston, and have the cylinder plated.
  • 123BigcoopDawg576
Posted July 29, 2009 - 01:00 PM
I'll have the cylinder plated.
If your just doing a rebuild, all you need to have done is a quick hone...no need to replate :thumbsup:
  • CanadianWR450
Posted July 29, 2009 - 01:09 PM
Dawg, check this thread out, and it will explain my situation a lot better......
http://www.thumperta...ad.php?t=804479
  • 123BigcoopDawg576
Posted July 29, 2009 - 02:35 PM
Ouch :thumbsup:
