What gives
9 replies to this topic
  • mmbasa
Posted September 21, 2002 - 02:44 PM
Just changed the oil (4R), no filter change. Measured out exactly 1300cc. Tried to start the bike but thats a different story let it run for a minute or two and checked the oil level. Not even on the stick, add some or let it run again, still not even on the stick. No leaks because I checked. Added some more all total about 1550cc. The manual says 1300 though, am I doing something wrong what do you normally but in. now its way high on the stick. This has happened every oil change since I got the bike in march.
  • Dan_from_HB
Posted September 21, 2002 - 02:48 PM
I've always added 1500cc, and it seems just right.
  • mmbasa
Posted September 21, 2002 - 02:53 PM
The manual gives three diffent measurements, I 'm just wondering why it goes from not even registering to the top of the stick with such a small difference in quantity.
  • ratbiker
Posted September 21, 2002 - 03:29 PM
since the last little bit is in the neck of the frame(a small confined space)it doesnt take much to go from nothing to too :) much!
  • Kevin_in_New_Hampshire
Posted September 21, 2002 - 04:37 PM
did you at least clean the filter?
  • AZWR426
Posted September 21, 2002 - 05:16 PM
Hope so!!!!!!!!! Nothing like clean oil through a dirty filter to brighten your engines day.
  • mmbasa
Posted September 21, 2002 - 07:32 PM
Ah yeah
  • SealClubber
Posted September 23, 2002 - 03:37 PM
If you took out and cleaned the filter that would be the same as changing the filter as far as oil amount is concerned.
  • AZWR426
Posted September 26, 2002 - 06:52 AM
[ September 26, 2002, 09:53 AM: Message edited by: AZWR426 ]
  • sabin
Posted September 26, 2002 - 08:29 PM
you have to actualy drive the bike for like 5-10 min to get the true reading.
