WR Tank on a YZF
5 replies to this topic
  • Jeepentj
Posted July 25, 2009 - 07:20 AM
Hello.
Can somebody tell me if a tank from a 2007 WR (first year aluminum frame for the WR) will bolt right on to a 2006 YZ (first year aluminum frame for the YZ)? Do I need to change the shrouds and/or the seat? Or will it just not even fit?
I'm hoping I can bolt it on without having to change any of the hardware (shrouds and tank).
Thanks,
David
  • ben_suhard
Posted July 25, 2009 - 03:32 PM
I've used a 3.2 gal on my YZ before without having to change the hardware, but I think I heard that the WR has different hardware.
You could try calling Clarke tanks, they should be able to tell you.
http://www.clarkemfg...ndex&cPath=31_3
  • Yamdog
Posted July 30, 2009 - 08:42 AM
The WR tank and shrouds are different but the mounting position is the same. If you put a WR tank on a YZ you would have to use the WR shouds and you may want to change the petcock since it is different also.
  • cowboyona426
Posted August 03, 2009 - 08:21 AM
Does anyone know what is different about the WR shrouds, or if YZ shrouds could be modded to fit the WR tank? I'd hate to lose my graphics if I could help it.
  • TnTFx
Posted August 05, 2009 - 01:54 AM
WR shrouds are not as tall as the YZ's are.
  • yz_for_me
Posted August 06, 2009 - 02:53 AM
I put a WR tank on my 07. The YZ shrouds are different and you will need the WR shrouds to do it right. My WR tank came several days before the WR shrouds did. I was able to mount the YZ shrouds on the WR tank with 3 of the 4 mounting bolts. It didn't fit quite right, but it worked in a pinch for me. I wouldn't recomend using the YZ shrouds on the WR tank as a long term solution though.
  • Hot  50 replies
  • On January 15, 2017
  • 0 replies
  • Hot  38 replies
  • 5 replies
