Heads up! 06(-09?) Fork Base Valve plastic cracks
3 replies to this topic
  • ben_suhard
Posted July 24, 2009 - 07:21 PM
This is just a heads up about the 06(-09?) Kayaba SSS fork base valve plastic chamber. One of mine was cracked, and apparently quite a few other owners have had the same problem. MXA mag consulted Pro Circuit, and they said the simple preventative measure is to drill a small hole in it.
Here's the MXA article http://www.motocross...E802C43DAFDFB23
  • nickeenoo
Posted July 24, 2009 - 07:45 PM
Nice reminder; this has been an issue for a few years. I believe the 08-09 already have the hole drilled? I'm sure someone else can verify. There is some good info on this issue:
http://smartperforma.../YZMODASSEM.htm
Nate
Posted July 24, 2009 - 07:55 PM
Not news, but as said, good reminder.
http://www.thumperta...ad.php?t=650136
http://www.smartperf.../YZMODASSEM.htm
There has been some debate over whether the the problem is truly related to hydro-locking the free piston. Dave Johnson (DaveJ) has seen a couple of pistons break in spite of the fact that they were already drilled, and I don't recall what he has discovered since then.
Regardless, The mod improves overall suspension action by increasing the air volume over the free piston, so that only the ICS spring has a significant influence on the free piston pressure, so it's a good thing to do in any case.
  • ben_suhard
I obviously haven't spent enough time on the forum! I might drill a few more holes in mine.
  • 0 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  28 replies
