2009 Yz450f best exhaust?
19 replies to this topic
  • yz450fcranker
Posted July 24, 2009 - 03:29 PM
ive been searching for the best exhaust for power for riding in the sand all i have found was that drd is the best all round pipe and yoshimuras are a bit stronger on top so which one should i get note i will buy normal stainless steel or aluminum
  • Justin89
Posted July 24, 2009 - 06:24 PM
DRD SS System....by far best bang for buck!:worthy:
Posted July 24, 2009 - 08:07 PM
My take:
http://www.thumperta...676#post7489676
  • ben_suhard
Posted July 24, 2009 - 08:45 PM
I'd get Dr.D.
But if you haven't already, read this thread http://www.thumperta...ad.php?t=462987
Posted July 25, 2009 - 06:25 AM
To read eltoro's complaint about the header/oil filter interference one would think it was a major problem; it's not. And, BTW, as far as having everything worked out before building, you should know that Yamaha did exactly the same thing for the first 3 years of YZ400/426 production, and in fact, the header usually had to be completely removed.
The DRD header need only be loosened and pulled upward less than half an inch to remove the upper front bolt holding the cover. Only the outside nut holding the header needs to be bothered with. Not really a very big deal once you stop whining about it. The pipe could have been made to clear it, but it wasn't. Big deal.
I substituted a stud and nut for the long bolt, and I remove the cover without disturbing the header.
  • earthmx
Posted July 25, 2009 - 12:09 PM
bills pipes
  • yz007f
Posted July 26, 2009 - 07:45 AM
DR.D and then use the rad lowing kit!!!!
  • salasmauricio
Posted July 26, 2009 - 09:00 AM
Grayracer, could you please explain this to me?, sorry I'm losing my english skills, you're saying there's a way to change the oil filter without loosing the header of the DRD system? do you have pics? This is the main reason why I wasn't completely sure about DRD besides all the good comments.
Thanks:thumbsup:
  • yz450fcranker
Posted July 26, 2009 - 01:46 PM
seems like i will go with Drd and call it a day thank u all for the help
  • Wes Woodin
Posted January 12, 2010 - 06:16 PM
one more for dr d ti/ti. I have used them for years and love them. Just make sure you take the screen out.
Posted January 12, 2010 - 08:30 PM
¿Why?
  • Wes Woodin
Posted January 13, 2010 - 08:05 AM
increase the flow rate. I believe it adds more power.
  • myoung
Posted January 13, 2010 - 08:30 AM
Kinda like a placebo?
One of these days I would love to see someone do dyno numbers on this and put this debate to bed. There's guys that tell me they can feel it, but I can't tell a difference.
Posted January 13, 2010 - 08:35 AM
I believe that if you hold onto this magic feather, you can fly.
I run the DRD system with the sparky in place out of necessity (rules) and I can flat out tell you that whether a dyno can tell it's there or not, I have $50 that says you can't (my son already lost that bet).
The one downside to running it is what happens if the pipe starts blowing packing out. It could theoretically pack up on the screen and cause problems. In two years, this has never happened.
  • Fabulous
Posted January 13, 2010 - 10:01 AM
I got a really nice Jardine RT-5 system new off eBay for $170 Canadian, and it comes with a spark arrestor. It seems to have about the same sound output as stock...maybe a bit more of a growl, but not louder. The power difference is a lot through the bottom and mid from what I felt, and the fit/ finish is excellent! It is a stainless header system with a polished aluminum can, with a really nice carbon fiber end tip. Thumbs up from me.
  • Wes Woodin
Posted January 13, 2010 - 10:13 AM
:banghead::lol::bonk: Classic
  • Wes Woodin
Posted January 13, 2010 - 10:15 AM
This has happened to me, and you know I had the screen out. I wonder what would have happened if I had the screen in.
  • Gunner354
Posted January 14, 2010 - 10:15 AM
Gray,can please post pics and specs of the stud and nut that replaces long oil filter bolt for those of us that use the Dr.D pipe.
Posted January 14, 2010 - 10:34 AM
Not without taking the bike apart, no.
But the bolt that the stud replaces is 65mm long, so you would need to find a M6x1.0x75mm stud (good luck with that), or a bolt at leas that long and cut it down and thread the end yourself (which is how I dealt with it). The length is something you'll need to experiment with, as it needs to bottom out in the case, but still extend only as far as one or two threads past a low profile lock nut.
The nut can be difficult to get onto with an open end wrench, and is much easier to deal with by using a custom ground box end. I do sometimes wonder if it's really that hard to loosen the header and pull it out of the way, frankly.
  • yz450fcranker
Posted January 04, 2011 - 06:41 PM
at last i got a jardine rt-99 exhaust it might not be the best but it works and adds performane and sound http://www.facebook....725833
  • Hot  47 replies
  • 0 replies
  • Hot  38 replies
