Quick Timing Chain Damper ?
1 reply to this topic
  • S2P
Posted July 22, 2009 - 04:38 PM
I found why my bike (02 426) won't run. I believe my timing chain is stretched.The damper bottoms out and chain is not tight,found adjuster all the way out.
Do I need to/Should I replace dampers as well?
I don't want to spend another $100 if it is not neccessary. Thanks
  • BAHeron
Posted July 23, 2009 - 08:52 AM
I had a stretched chain on my 00', same deal wouldn't run, jumped timing. Found the chain was 1/2" longer then the new one. Changed the chain only, and she runs like a champ. No need to spend the extra $, as long as the damper goes in and out smooth.
