YZ450 Flywheel Weights?
16 replies to this topic
  • sketchyhayde
Posted July 21, 2009 - 04:01 PM
Would A YZ450 Preform Better for a novive With flywheel Weights?
  • dirt_rider_39
Posted July 21, 2009 - 04:12 PM
Yes!
It will help starting, and not stall as easy,.....keeps engine momentum going when climbilng hills, helps with slippery conditions, lets you control rear wheel spin better, eases the power delivery....
many pro riders use them...why not you too?
  • sootgrinder
Posted July 21, 2009 - 04:34 PM
I just put a 9oz heavier flywheel from Steahly. It made a world of difference!!! the bottom end is really smoothed out and my stalling issues completely disapeared. It starts easier, it runs smoother, and even though some of the snappyness is gone, I am way faster in the woods. I give it a big double thumbs up.
Soot
  • KAS
Posted July 21, 2009 - 09:12 PM
Yes, definitely.
  • WB450
Posted July 22, 2009 - 07:11 AM
Roger that, you will love it.
  • cowboyona426
Posted July 22, 2009 - 07:15 AM
I'm the odd man out on this one... I put a GYT-R heavy off-road flywheel weight in my 06 and while it did help maybe a little bit, it will still flame out in tight trails like nobody's business.
  • sketchyhayde
Posted July 22, 2009 - 02:40 PM
also do you recomend bolt on and weld ons
  • KAS
Posted July 22, 2009 - 06:14 PM
True, my bike will still stall easier than say, an off-road 450, or a 2-stroke.
But its still less stall-prone than stock.
  • cowboyona426
Posted July 23, 2009 - 06:43 AM
Mine stalls WAY too easily, even with the heaviest option flywheel available from Yamaha. I think I have clutch issues... I'm going to try a different oil and inspect the clutch again and see if I can get to the source of the problem.
  • WB450
Posted July 23, 2009 - 06:56 AM
Get the heavy GYTR flywheel, it replaces the stock one.
With all parts check the TT store first, if they don't offer one then.
http://www.powerpart...r-flywheel.aspx
  • DPW
Posted July 23, 2009 - 07:20 AM
If you can't find the flywheel listed with the TT store email them. They've got GYTR parts before for me that weren't listed.
  • KAS
Posted July 23, 2009 - 10:13 AM
The Steahly flywheels for the '06+ bikes are a totally new replacement flywheel with the weight welded on.
  • buzzfin
Posted July 23, 2009 - 01:34 PM
For what it's worth... The Steahly and the GYTR Off-Road flywheel are EXACTLY the same. They even come in the same exact packaging. I'm thinking Steahly must make them for GYTR - however the GYTR is cheaper.
  • eddie06450
Posted July 23, 2009 - 01:48 PM
Well i have looked at both and and Steahly makes a 9oz and 5oz, the GYTR only is 4.83oz what is you alls input on the different weights.
Posted July 23, 2009 - 02:11 PM
You haven't looked closely enough; Yamaha has two:
http://www.yamaha-mo...5/0/detail.aspx
http://www.yamaha-mo...7/0/detail.aspx
I have the 9.21 oz. GYT-R (GYT-2S297-50-50), and it's the flywheel the bike should have been built with. IMO, the lighter GYT-2S297-50-00 is a waste of time.
BTW, the pictures are of flywheels for the previous 450 models.
  • Wiz636
Posted July 24, 2009 - 07:44 AM
Here is the stock flywheel and the GYTR +9.21 oz offroad flywheel for the '08 and I would assume for all '06+ YZ450s
  • Johnnyv04 yz450f
Posted January 05, 2015 - 12:25 PM
I'm looking for a heavier flywheel for my 2004 yz450f, that is not a bolt on. I can't find 1, does it exist? Gytr said they didn't carry it when I looked up my bike. Will the 13oz bolt on work just the same ???
  • On January 15, 2017
  • Hot  36 replies
  • 5 replies
  • Hot  47 replies
