Oil leaking out of hole on right side of cylinder?
3 replies to this topic
  • centralmax
Posted July 18, 2009 - 07:22 PM
What is the hole on the right side of the cylinder and why is there oil leaking out of it?
  • 426 NOOB
Posted July 18, 2009 - 07:45 PM
That hole is a drain for the spark plug area. When you get water in there it allows it to drain rather than build up. I doubt its oil, but more likely dirty water coming out and if it is oil, tighten up your spark plug.
  • papxj
Posted July 18, 2009 - 08:22 PM
Did you wash your dirty bike and spray dirty water up there? It's probably water. Taste it to be sure...
Posted July 18, 2009 - 10:05 PM
If you have oil coming from there, there are two possible causes
  • The spark plug could be loose enough to leak combustion "goo" around it's base (not likely, unless you're burning a lot of oil)
  • The cam cover gasket is leaking into the plug well
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
  • 9 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  79 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
