3x3 mod for Drz400s
10 replies to this topic
  • tdtravis80
Posted July 18, 2009 - 03:20 PM
I am planning on doing the 3x3 mod for my 2000 Drz400s. I bought a FMF Power up jet kit off the world wide web but it says its for a mildly tuned machine using the stock airbox. It comes with main jets .132,.134,.136. If I do the 3x3 mod the airbox is not going to be stock any more right? is this the wrong jet kit for the 3x3 mod? I appreciate your imput
  • wvdualsport
Posted July 18, 2009 - 03:24 PM
You'll need a larger main jet.
  • suzuki sm nut 123
Posted July 18, 2009 - 03:29 PM
yes, that would be the wroung kit. A 3x3 w/ stock pipe calls for a main jet 155 so you can see you are not even close. It has bin said many times before get the JD kit and you will be set JDS005
  • drz400s_guy
Posted July 18, 2009 - 03:55 PM
Return it and get a JD kit from the TT store and you will be set on the right jet sizes.
  • bumtarder
Posted July 18, 2009 - 05:23 PM
that jet kit is made by dynojet(#3109) i believe and it was only ever marketed as a stage 1.our jetting expert eddie developed the stage 2 for that kit here a while back.
for the stage 2(3x3 airbox mod)you should also get the #25 pilot jet and the kientech s/s socket head float bowl screws.you won't necessarily need to buy extra main jets if using the stock exhaust.this will probably get you close;
3x3 airbox
stock 142.5 main jet
DJ slide spring
DJ needle
clip 4(with all stock spacers)
13mm float level
25 pilot jet
2 1/2-3 turns stock fuel screw
I'll see if i can dig up some pictorial how-to's for ya.
http://web.archive.o...8/drz.info/drz/
http://www.thumperta...ad.php?t=334539
  • tdtravis80
Posted July 18, 2009 - 06:42 PM
I dont have stock exhaust I have a fmf power core exhaust on my bike so what do I need for that exhaust and the 3x3 mod
  • tdtravis80
Posted July 18, 2009 - 06:51 PM
I should be able to use the needle I got with that kit and just buy the 142.5 main jet and the 25 pilot jet that i need on its own right. or should i return the kit if i can?
  • bumtarder
Posted July 18, 2009 - 06:55 PM
the stock main jet on your bike is a 142.5 and should work fine with the fmf pipe.
most on this board prefer to use the much more complete james dean jds005 jet kit.if you can return the kit you'd be better off imho.but the dynojet kit will work.
  • tdtravis80
Posted July 18, 2009 - 07:09 PM
what all comes in this jds005 kit and i appreciate all the info you are giving me bumtarder Im pretty stupid when it comes to this stuff
  • bumtarder
Posted July 18, 2009 - 07:24 PM
it's complete with all the main jets you'll ever need for the mikuni as well as 2 adjustable needles,a 25 pilot jet,s/s socket head float bowl screws,drill bit and screw for removing the fuel screw plug etc.and great instructions.it's the one most use on the stock mikuni until you go for the upgrade to the 39 fcr-mx carb.
read thru the master 3x3 thread in the drz faq forum at the top of the page to get caught up.there's a ton of excellent reading in there for the new guys.
  • tdtravis80
Posted July 18, 2009 - 07:45 PM
thanks alot for all your input you rock dude
My dirtbike accedent that just changed my life by Colorado dirt bike kidz
  • Hot  142 replies
I think I am too stupid to install throttle cables... by razzledazzle
  • Hot  46 replies
Suzuki DR-Z400E 2016 by DirtShow
  • 0 reviews
DRZ to become Adv bike, what bike for DS & singletrack? by BlueHeart
Upgrading from S to SM forks and rear axle worth it? by arpuS
  • Hot  50 replies
