Hi Guys,
Removed my AIS system today , made a block off plate and hauled out all the hoses and such. I'm now reading that i probably should not have done this with the stock exhaust.
"The AIS (Air Induction System), is a control valve under the left shroud that has the chrome pipe that goes to the front of the head near the exhaust port. It also has a hose that goes to the right front side of the airbox near the airbox door hinges. It can safely be removed too. But it is only advised to remove it if you have an after market exhaust. If you have the stock pipe you need the AIS or else it will ruin the CC in your pipe. The AIS is basically an air pump like pollution control system that injects air into the exhaust for a cleaner burn. To remove the AIS, just unplug it and remove the control valve. Buy or fabricate a plate to block the hole in the front of the head, and then put a rubber 1/2" cap on the fitting on the airbox. Chuck the control valve, hose, and chrome pipe in your junk box with the rest of your take offs. Done deal."
So do you guys think i should put this system back on?
As far as i know i will not be getting a after exchaust in the future.
