Best way to flush an oil system?
10 replies to this topic
  • 84rm250
Posted July 16, 2009 - 05:04 PM
Valves broke on my 426 and took out a list of parts, pulled oil filter and it was full of shavings.
How do I make sure all of these shaving are out? I tryed flushing the crankcase out with diesel fuel. Will this be good or what else should I do? Thanks for any help
  • desert-rat660
Posted July 16, 2009 - 06:11 PM
the best way would be dissasembling the engine, im sure the pickup screen has alot of metal stuck in it
  • 84rm250
Posted July 16, 2009 - 07:51 PM
Any other way besides compleat tear down?
  • nickeenoo
Posted July 17, 2009 - 05:17 AM
Nope. Why would you want to risk it?
Posted July 17, 2009 - 09:05 AM
Consider that flushing an oil system necessarily involves pumping whatever it is you want out of it through it several times in order to get rid of it. It depends on what the situation is, and what you're trying to accomplish, exactly as to whether it's advisable or not.
  • 84rm250
Posted July 17, 2009 - 09:40 AM
I just dont want to wipe out any other parts after i put it back togethere. I dont really have the time or money or space to tear the whole motor down. I rinsed out the crank case with diesel with and with out the drain plug in many time, abput 3 gallons weather.
After I start it for the first time should I quickly shut it off and change the oil and filter again?
Should I rinse the tank in the frame out?
  • Hughes
Posted July 17, 2009 - 12:53 PM
There is no other way. The enigne needs to to completely torn down for proper repair or it's just going to explode again.
  • husqy360
Posted July 17, 2009 - 01:41 PM
i had same thing and 3 tanks after new top end the rear wheel locked ones again, but this time it was nedded top and bottom.
  • devo1
Posted July 17, 2009 - 02:31 PM
It's really not a big deal to pull the motor and split the cases. It can be done in 4 to 6 hours.
When my bike stripped 3rd gear the metal pieces scored the oil pump.
  • 84rm250
Posted July 17, 2009 - 07:58 PM
so how far apart do i need to take it? split the case's and clean/inspect everything? What kind of tools will i need? I have a repair manual that should help me thru it. any kind of help would be awsome.
  • 02WR426Cali
Posted July 18, 2009 - 08:13 AM
This is on a 2 stroke but there isn't too much difference, same concept just a couple more parts in the 4 stroke but check out this vid and others on there. It will give you an idea about it. There are 3 parts to this tutorial
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  36 replies
  • 0 replies
  • Hot  79 replies
