sflash868 said:
I can't track this down and I"m starting to think it's just normal. I have an engine vibration that kicks in at a distinct RPM that vibrates the bike so much that my feet are going numb on the pegs. Soon as I pull clutch in it's gone. It's 100% engine related. I don't know what to check. Bike runs great. Any ideas besides wrapping my pegs in foam? It didn't used to do this.
In fifth gear it's 57 mph when the vibrations comes in so about 5500 RPMs. There is a change in noise from the motor too. Valves do this? I"ve never checked them or the timing chain? Bike has 12K miles. 06 DRZ S
Any thoughts? thanks..
So this only happens at 57 mph?
But if you pull the clutch in, it stops?
What happens if you run it to 65? Is it still there? (if not, it's probably tire related actually).
What happens when you pull the clutch in if it's still there at 65?
I don't think your problem is engine related if it only happens at 57 mph+
If it happened at 5500 in every gear, then yes, engine.
Could be tranny, chain, tires, but I really doubt it's the valves, pistons or crank.
I had a similar problem. 6500+ rpm would make my hands go numb. Over time, it started to hit my butt and feet.
Solution: replaced the whole engine. It wasn't cost effective to hunt down the problem.
