Which side of the starter idle gear does the washer go on? The posts indicate inside, but the diagram seems to show outside. The ID of the washer matches the inside location.
Starter clutch fix - washer location
Started by DaveW2, Jul 14 2009 06:02 PM
3 replies to this topic
Posted 14 July 2009 - 06:02 PM
Posted 14 July 2009 - 08:42 PM
Thanks Eddie. In the other post you said:
"there is no shim or clip on the on the out side.
2 shims.1 on each side of the clip."
So this diagram is wrong. WASHER 09181-12130 is shown as one one each side of the gear
http://shop.thumpert...2004&model=1916
