For anyone who buys this eBay Fcr-Mx carb here is what you need to do;
*Fcr-Mx Carb off eBay*
http://cgi.ebay.com/....6%3A2%7C39%3A1 ***FYI if you submit a "best offer" he'll sell it for $300 shipped!!!***
Buy the following oem Suzuki parts;
P/N 13111-29F00 OEM Suzuki E Intake Manifold $13.48
P/N 09402-58208 OEM Suzuki Clamp $3.44
P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple $7.33
JD Jetting kit; 165 main, 42 Pilot, red JD needle 4th clip down, 85 starter jet, 70 pilot air jet, quickshot 2 AP cover, Merge AP spring, Tokyo Mod Fuel Screw (or the like) and float bowl drain bolt. (1) turn out on fuel screw. (1) turn in on AP screw.
I also have 3x3 mod, full Yoshimura carbon/ss exhaust with baffle/spark arrestor removed, K&N air filter.
This carb has NO popping on decel and starts without using your choke or pumping the throttle. It idles PERFECT and has NO BOG off idle.
