07 Wr 450 sub frame.
9 replies to this topic
  • Jeff_Steckline
Posted July 14, 2009 - 04:05 AM
I have worn threw my sub frame, from boot rub. I am now a believer in frame guards. Does anyone know if I can use a 07 YZ sub frame? Please, any cheap suggestions. I was going to shop eBay. Thanks. Jeff S
  • mikenash
Posted July 14, 2009 - 09:03 PM
Call me I know the cure and no you don't want to run frame guards that only makes it wear out faster.
  • Icelandic_amateur
Posted July 15, 2009 - 04:47 AM
Im interested in frame guards as well. - I hope someone can come up with good suggestion.
  • Jeff_Steckline
Posted July 15, 2009 - 07:18 AM
Mike, I'll give you a call. Explain for the greater good why we don't want to run frame guards? Thanks bro... Jeff S
  • SJMC_DON
Posted July 15, 2009 - 02:29 PM
YZ subframe will not work...
I lucked out and found one on e-bay for $35 when I needed to replace....
cant you just cut and splice in some Alum. square stock?
I am curious bout the frame guards too....
  • MT-01
Posted July 15, 2009 - 11:42 PM
can you please describe what you mean by "wearing through the subframe"
Have you actually worn a hole through it???
My WR is 6000 k's old and the subframe is fine.....
  • Jeff_Steckline
Posted July 16, 2009 - 05:20 AM
Right where the ankle on my boot (Sidi boots) meets the subframe, I have worn threw the sides of the subframe on the outside edges. The cracks are about 1/2" long and run vertically up the subframe.
Don, thanks for the info on the YZ subframe. I thought I read somewhere you could swap out the WR for the YZ but couldn't recall if It was real or just dreamed up.
  • chris_TTR250
Posted July 16, 2009 - 10:30 PM
I noticed I was wearing through the sub frame, and even rubbing on the frame.
I bought some of the GYTR aluminium frame guard and no longer have a problem.
Theres no reason why you could'nt cut out the damaged section of sub frame and weld in some new box section.
  • juntini
Posted July 17, 2009 - 09:07 PM
Where did you find the frame guards? I've been looking online and have only found some carbon fiber ones from light speed. Thanks:bonk:
  • chris_TTR250
Posted July 18, 2009 - 02:04 AM
Try:
http://www.bikebiz.c...md=40010.702731
