where to get X front caliper?
12 replies to this topic
  • Joe_Fish
Posted 13 July 2009 - 08:46 PM
After some discussion I decided to go with the X wheels for my street set-up. Now I need to find an X caliper. I have found Power Parts Plus the cheapest so far, any place have a better deal? I'm looking at 201 for the front caliper, 130 for the front disk and 59 for the rear disk plus about $12 in hardware.
  • Jaynen
Posted 13 July 2009 - 08:49 PM
Yamaha parts nation had the best price for me and I got my local dealer to price match.
PS if you havent found a set of stock X wheels I think Forrest at wheeling cycle supply was selling some
SKU: 3D7-2580T-10-00
CALIPER ASSY (LEFT) 1 $178.58 Add to Cart
  • Joe_Fish
Posted 14 July 2009 - 07:09 AM
thanks for the source. :thumbsup:
I actually did buy the wheels that Forrest was selling. :ride:
  • Jaynen
Posted 14 July 2009 - 12:39 PM
Do you already have tires or are you figuring that out? where in cali are you?
  • Joe_Fish
Posted 14 July 2009 - 12:55 PM
I have tires coming.
Located in the San Jose area.
  • Thumpthing Old
Posted 14 July 2009 - 02:16 PM
You could just get a caliper relocation bracket and run a big disc with the R caliper. I'm really happy with that set-up (for street riding). No brake bleeding required.
  • Joe_Fish
Posted 14 July 2009 - 02:31 PM
I thought that setup is for the R hub not the X hub?
  • Jaynen
Posted 14 July 2009 - 06:38 PM
It is afaik. There is no relocation kit that fits an X wheel but relocates the R caliper to work
  • Joe_Fish
Posted 14 July 2009 - 07:59 PM
So I would use the X wheel and X rotor with the R caliper and a 320mm relocation bracket from a current model wr250/450f?
  • markgyver
Posted 15 July 2009 - 05:40 AM
Or you could've just bought my wheels that came with the caliper and disc..
j/k good luck, Mark
  • Jaynen
Posted 15 July 2009 - 06:35 AM
The stock X rotor is a different thickness than an R rotor and uses different brake pads on the caliper
The stock X rotor is 298mm or something like that so a 320mm relocation bracket would not work for the stock rotor
The X hub on the front at least is not the same as the R either so you cannot bolt a 320mm relocation bracket setup onto the fork and have it work on the X wheel because the rotor wont go on.
Believe me I tried and just went through this.
This is what an EBC brake kit with relocation bracket for the WR/YZ 250/450 looks like on a WR250X front wheel
Notice anything wrong :banghead:
The guys using relocation brackets are either a) using custom laced wheels to R hubs or b) using WR250X wheels still relaced to an R hub
If someone wants to prove me wrong by all means do so but no one could find a relocation bracket designed for the X hub/rotor to work with the R caliper for me, and the brake kits are caliper + rotor and those rotors wont fit
  • Joe_Fish
Posted 15 July 2009 - 06:46 AM
That was my original impression, that the bigger disk would only bolt up to the R hub. I have X wheels coming so the X rotor and caliper is the way to go. I figure if the X caliper is only $170 and it comes with pads its really not that bad of a deal considering I got a really good price on the wheels and tires.
  • Jaynen
Posted 16 July 2009 - 07:33 AM
Price wise its still cheaper than getting wheels laced to R hubs etc. Its just more hassle when swapping calipers and bleeding brakes.
I still need to replace my master cylinder screws that started to strip be VERY careful or save yourself the trouble and buy new stainless ones immediately
