Normal: 61 - 65 mpg (U.S. gallons)
Highest: 69mpg
Lowest: 55mpg
I normally get 61 - 65mpg (U.S. gallons) whether I am commuting 16 miles back and forth to work with cold starts, doing long, fairly high speed rides on the tarmac, or hammering it in low gears out on the trails. Two exceptions have occurred outside of that bracket. One high. One low.
I once got nearly 69 mpg ride where I did an entire tank on an meandering 45-50mph gravel road in high gear. The other exception was a hard trail ride while in MN (near sea level) where I only got 55mpg; my lowest mpg ever. My other two tanks of gas, near sea level, were up in the usual 60mpg range, but those were country road cruising where I would have normally been up around 65mpg. In MT, my usual riding altitude is 4,000 - 6,000 ft.
Total weight of rider, gear, and full dirtbagz is usually around 190lbs. Bike is stock in regards to anything that would impact mileage (exhaust, programmer, gearing, tires, AIS/EXUP, speedohealer, etc.). I'm calculating mileage using the stock odometer reading, so that might throw my "calculated mpg" vs. "true mpg" off a bit.
I try to run premium when available, but don't worry too much about running mid or regular if that is all that is available, especially since real summer heat hasn't kicked in here, yet. A few days in the 90s, but we haven't had the usual July 100 degree heat yet.
It seems there is a wide variance in reported mileage, which is common with any other bike-specific mpg thread. Differences in riding style, factory build, break in style, gas quality, altitude, rider/luggage weight, aerodynamic changes (windshields, saddlebags), and especially bike mods, like gearing, tires, FI programmer changes, etc leave so many variables, it's tough to say was is normal mpg for a specific model. It's still interesting to see everyone's reported mileage, though.
