'08 Drz 400 SM Solenoid
8 replies to this topic
  • Metalorama
Posted July 13, 2009 - 01:18 AM
Hey guys, I was wondering if someone could help me with this...
I just recently jetted my bike, thanks to help from here :worthy: , and found that the power gain was not quite what I expected. Browsing forums I read something about a solenoid in some engines and on closer inspection of my carb realised I had one. Long and short...
Was wondering if anyone has removed solenoid before and if so could help with details of what is involved, would be much appreciated.
mucho gracias :banana:
  • eddie odell
Posted July 13, 2009 - 11:49 AM
The "solenoid" you speak of is probably the air cut valve. It has nothing to do with making power. Its only there to help minimize the pop that occurs when the throttle is suddenly close and the engine generates lots of extra vacuum while the throttle is still closed. At this point the mixture is forced quite lean, this device momentarily richens the mixture to help reduce the pops.
  • Harvey600
Posted July 13, 2009 - 11:56 AM
get rid of it and the pair valve, on EU/UK bikes, the pair valve injects air into the exhaust when the throttle is closed to burn unburnt fuel. The solenoid controls the speed of the slide inside the carb in the lower 3 gears, disconnect the pipe going to the top of the carb, block the top fixing off and the hose too,
Remove the pair valve and plate the hole using the existing gasket and a piece of metal. Do a search for pair valve, Headster wrote the best thread.
Once you've done these things the bike improves loads!
  • eddie odell
Posted July 13, 2009 - 12:05 PM
Once you've donr these things the bike improves loads!
Sorry forgot about smog motors, if so then Harvey600 is correct also.
  • Harvey600
Posted July 13, 2009 - 12:16 PM
:worthy: The pair valve and the carb solenoid were Suzukis last attempt to get the DRZ through Euro emissions, sadly we don't get the DRZ new here anymore. :banana:
  • Metalorama
Posted July 14, 2009 - 12:05 AM
Cool, that pretty much confirms what I read. Thanks alot guys, my first bike and pretty new to this so appreciate all the help I can get.:worthy:
  • Harvey600
Posted July 14, 2009 - 07:10 AM
No worries, :worthy: don't forget to check out the FAQs at the top of the page, lots of good hints on maintenance and mods up there too! Enjoy!
  • Metalorama
Posted July 16, 2009 - 01:19 AM
Thanks man, I appreciate it. Jobs done, bike seems bit more willing to accelerate through first 3 gears, so I'm a happy man. :banana:
  • Harvey600
Posted July 16, 2009 - 08:47 AM
Any time, I don't claim to have all the answers, but, I don't mind helping to work stuff out.
Drz400s petcock question by JEEPNICK
  • Hot  27 replies
CRD HEADER and STOCK S SILENCER? by Alex Wilford
2003 Drz400s struggling at 55 mph? by kingbluey
  • Hot  65 replies
How to avoid head failure? by Maxed-out
  • Hot  44 replies
I think I am too stupid to install throttle cables... by razzledazzle
  • Hot  46 replies
