2009 YZ450 Oil Breather hose
4 replies to this topic
  • Hawaii_Racer
Posted July 12, 2009 - 06:22 PM
Ok so I have a new 2009 YZ450 and I am getting a LOT of oil out of the head breather hose. I ran it quite a while with it bowing oil out (didn't notice) engine didn't seize so could I have done any other damage? What could cause oil to blow out of this? I swear I put the proper amount of oil in. The bike is only 4 months old.
Posted July 12, 2009 - 09:18 PM
But did you drain the proper amount OUT? How many drain plugs did you remove in the process, and did you remove the dip stick prior to draining?
  • Hawaii_Racer
Posted July 12, 2009 - 09:38 PM
The amount I drained looked pretty small (hence I'm wondering since it didn't seize what else could have gone wrong?) When I drained it I drained the two bolts and removed the filler cap. I however did not remove the dip stick. Could that have prevented some of the oil from coming out even though I had the filler cap removed?
Posted July 13, 2009 - 07:23 AM
... I however did not remove the dip stick. Could that have prevented some of the oil from coming out even though I had the filler cap removed?
Yes, that's why I brought it up.
The proper amount after draining the "tank", the sump and the filter is exactly one liter. Fill a fresh quart to the one liter line and you'll be good.
  • Ga426owner
Posted July 13, 2009 - 09:06 AM
Was the bike warmed up or cold before you drained? A warmed bike drains more oil.
Did you drain any oil from the oil filter cavity and put in a clean filter? The oil passages there and throughout the bike hold quite a bit of oil. I also very lightly push the kick starter down a couple of times with the kill button pushed. This also helps to drain more oil, but makes a mess if you do not have a oil catch under the bike. :worthy:
  • 5 replies
  • Hot  28 replies
  • 0 reviews
