So I have posted a couple times here before (well more then a couple, lol). I have a 1997 Honda XR 650 L which I am riding down to Mexico and hopefully Cost Rica. So far I made it down to California and I have been bumming around here for a while. I have noticed a few things on the bike;
1) Oil loss, on hot days (the hotter the day the worse) after alot of riding my oil level decreases. Some times just a little, other times alot (up to a litre yesterday when I put almost 1000 km on the bike at speeds greater than 100 km/h and temperatures around 25 to 30 degree's celcius.) A few people told me this is to be expected as the XR's are prone to burning oil, but I have also had a few people tell me alot of wrong information before so I wanted to check with you folks as well.
2) Engine Temp. / Oil Temp. I currently do not have any method or measuring any temperatures on my bike besides the most common one of placing my hand on the frame while riding and seeing how long it takes to get burnt. On cooler days I have been able to keep my hand on the frame almost indefinately, however on hotter days, especially the ones where I have been burning oil If I go to touch the frame my skin almost instantaneously sticks to the frame. Is it normal for the engine temperature/oil temperature to get this hot?
3) While I am on about the engine temp. I have been considering putting an oil cooler on the bike for Mexico, I am not sure if this is neccesary or reccomended pre-caution or simply crazy talk but I would love to hear your guys thoughts and perhaps some leads to where I could track one down or leads to how it is done.
4) Chain Stretch: When I left B.C. Canada, I adjusted the chain to the 4 cm or required slack which left the snail adjusters set at 35. Now I am 2700 km into my journey and my snail adjusters are set at 45 (maxed out) and my chain must have like 10 cm of slack in it. I ordered a new chain but I am wondering if this is common due to the fact that the drive train and everything else on that bike was designed for a smaller CC engine or there is something else I should be checking out. When I ordered the new chain I opted for a model or two up form the base line (reluctant to spend the extra $) But if I am right about the drivetrain I imagine a more expensive chain to prevent stretch should be neccesary. (The chain I ordered was about $80 USD, instead of the base line @ $40 USD)
5) Oil filter, I also ordered a new one of these as it recomends to change them with every oil change and I am coming up to the 3000 km oil change interval soon. Would anyone disagree with changing these filters more or less often then the manual suggests?
6) Stopper Plate: I believe is what the little thin piece of metal on the outside of the swing arm on the rear axle is called. I noticed my bike only had one on the left side when I took the rear wheel off, and for some reason I seem to recall my old 1984 XR200 having one on both sides, should my XR650L also have them on both sides? (the manual was no help here.)
7) Air Filter: I cleaned and oiled my air filter before I left and I should probably do it again and most certainly will have to do it in the future. I currently have what appears to be the original filter on there (resemble a car K&N filter). Unfortuneately due to lack of storage space on a dirtbike I left my air filter cleaning and oiling supplies at home and opte for the chain oil instead. I was told I could clean my filter in a solution of soap and water (with very little soap to water ratio) and oil it with small amounts of engine oil. I am not sure if this is true or not but seems reasonable. My other concern is as follows. Before I left home I modified the carb and air filter as per "Dave's Mod's" HOWEVER due to a tight budget I never purchased the Uni Foam air filter it suggests. How necessary is this filter? My concern being not only the money but the lack of supplies to clean a foam filter.
Thanks in advance for anyone who takes the time to read all this left alone reply!
Cheers, Adam.
