tx2whlr said:
I'm starting this thread in hopes of narrowing the problem down to a bad batch of pumps, and regaining faith in our beloved little bike.
mine is mfg date of 2/08 and vin of 001645
By the way turned the key this morning, fuel pump cycled and it fired right up. It was very hot here yesterday 102 or hotter and even at 11:00 last night it still wouldn't start.
Pete
mfg date 25Rr 2/08 vin 000270 1500klm (less approx 10%)
IMHO The pumps are cutting out under thermal overload generated by the pump itself not through ambient heat, although this will certainly have some effect.
A tell tell sign is the pump making a different sound from the normal 'whirr'
when the key switch is turned on.
Could the fuel be the problem? Having a chemical reaction on the plastic parts of the pump? Or just a bad batch of parts machined to the wrong tolerance?
Hope this helps.
