crankshaft jig tool thingy
18 replies to this topic
  • hi_im_sean
Posted July 08, 2009 - 04:12 PM
the thing you use to keep the crank true when you reassemble cases looks very easy to make. instead of paying the $100 for this thing: http://www.pitposse.com/crinjigto.html
you guys think this would work ok?
  • no1clyde
Posted July 08, 2009 - 05:02 PM
Yes it would work. I use to use 2 sets of small wedges I made, 1 set on each side of the rod with the rod at bottom dead center and the wedges on both sides at TDC. The tool I have was given to me or I would still be using the wedges. They are fork shaped so it is on both sides of the rod for even support. Good luck Sean, Im sure you can make something that will work.
Ed
  • KDXGarage
Posted July 09, 2009 - 03:47 AM
hi_im_sean, are you wanting one to keep, or just for one time use?
I have the OEM tool. I don't think it would be too easy to make, but not impossible.
  • Jeekinz
I use a wrench. If one of your wrenches don't exactly fit you can use a thick paper shim.
  • hi_im_sean
Posted July 09, 2009 - 05:17 AM
a wrench? thats a relief, i was curious how accurate these need to be, obviously not that accurate. kdx i was going to made one to keep, but i probably wouldnt use it again for 5 years or something, you never know. thanks guys.
  • Jeekinz
Posted July 09, 2009 - 05:56 AM
The wrench should fit like a feeler guage with a little drag. The slight angle in the open-end part allows you to bring the wrench up near the connecting rod for easy case assembly.
Like the chain breaker, I'm not a fan of single purpose tools. lol
  • ndekens
Posted July 09, 2009 - 09:05 AM
If you bake your cases and freeze the crank then you dont need any tools. The thing will simply slide together.
  • hi_im_sean
Posted July 09, 2009 - 11:24 AM
im not taking that chance, i was going to do that in addition
  • juliend
Posted July 09, 2009 - 03:38 PM
I put a wrench in mine when I put them back together. I also froze the crank overnight and heated the cases to 220. The thing slid together like butter. The wrench was probably unnecessary, but it's good insurance for sure.
  • daled
Posted July 10, 2009 - 05:13 AM
I surface ground two pieces of key stock and placed at either side of the rod. Thats when i noticed the the two internial surfaces of the crank are not flat or parrallel ! ! ! this was quite suprising to me.
  • don46
Posted July 10, 2009 - 08:28 AM
I wouldn't be relieved that using a wrench would indicate that its not that critical, and if you don't care how smooth your motor is or long long it will last, then your right it's not that critical. However, if you want you motor to run buttery smooth, perform to it's max potential and last for a long time, then it is critical. Granted you will probably never get to 0 but not unheard of top get to half a thousanth if your paitent. If you do your bike will run so smooth and perform better than it ever has. I might take some short cuts on some things, but never the crank, when my kid raced 80's you could tell a true crank from on that wasn't, and after the first I never lost another crank, its the heart and sole of your bike, make it right and you'll be happy.
Sorry jeekinz but I'm not feeling the wrench, right tool for the right job.
And as somebody else said heat and cold are your friends, not sure about the bake job, but I guess it could work, remember you have rubber seals installed before the bearings so don't get to hot.
  • BlazingTrailz
Posted July 10, 2009 - 11:41 AM
:worthy:
  • hi_im_sean
Posted July 10, 2009 - 12:39 PM
i completely agree, i know the seals have a temp limit, and i have considered that. i baked em at 200 F to get it apart and it seemed to have no visual effect on the seals. i always use temp differnces when i assemble interference fit componants, it just makes life easier and gives me peice of mind that i didnt damage a bearing by pressing to hard.
thanks for everyones input
  • KDXGarage
Posted July 10, 2009 - 12:54 PM
The OEM tool allows the bearing to be at the bottom, while the tool supports it at the top.
In the late 70's KX / KDX manuals, before the new tool was available, they show a chisel being used as a wedge.
  • Sideways91
Posted July 18, 2009 - 09:12 PM
Ed
are those goats in your avatar?
  • no1clyde
Posted July 19, 2009 - 06:01 PM
Now now, you know those are two of my dogs and Clyde is the one on the left. It was fun riding with you last week.
Ed
  • matt4x4
Posted July 20, 2009 - 04:00 AM
Seals hold up well beyond 200 f - they get way hotter than that every time you run your bike!
I also use a wrench as stated, cranks pins are in so tight it takes a LOT of force to dislodge one - chances are pretty slim you'd knock your crank out of true while tapping cases in place, you'd probably have to crack a case before knocking a crank out of true.
  • hi_im_sean
Posted July 20, 2009 - 10:31 AM
top end seals get above 200, sure, but i doubt the cranks seals do, id guess they run right around 200. but i agree, im sure they can handle a good amount of heat
  • matt4x4
Posted July 20, 2009 - 11:38 AM
right where the seal contacts the shaft and the shaft spins at 12000 rpm.....what kind of heat do you think is present there......
the heat from the top end migrates to the bottom end over time - if you run the bike for 2 hours non stop, the bottom end will probably be within a few degrees of the top end. If you run motos and it cools in between - probably like you said - not so much, but go for a nice road trip/trail ride.
Help ! It refuses to idle...no matter what.. by UglyCasanova
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  36 replies
Traction Issues by TheHondaRidingKxOwner
  • Hot  52 replies
01 KX 250 engine problem! Please Help! by AMP625
  • 3 replies
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
Is the stroke coming back? by MazdaMan
  • Hot  180 replies
