140 series pirelli XCMH rear- persistently out-of-stock?
8 replies to this topic
  • XR650L_Dave
Posted 06 July 2009 - 09:12 AM
Having trouble finding the 140 XCMH rear in stock anywhere- there a run going on for this tire?
Has anyone seen the 120 and 140 together, and can comment on relative sizes?
I know what the size diff is *supposed* to be, I also know a 140 series MT21 is a *lot* more aggressive than a 120 series.
Dave
  • gravitas
Posted 11 May 2011 - 08:28 PM
I purchased the 120 and 140 together because I was curious about the size difference. The only thing I can notice is that the 140 has a flatter profile and the beads are farther apart; but when you squish them together to match the width of the 120, the profiles are almost the same. I think the 140 is designed to be able to fit on a wider rim; they are both the same height (perhaps the 140 is a smidge taller with the beads squished together). Thats about all I can tell without them being mounted and inflated yet.
  • kenshaw720
Posted 11 May 2011 - 09:14 PM
Dave
http://www.motorcycl...-Rear-Tire.aspx
  • wvdualsport
Posted 12 May 2011 - 05:26 AM
Dunno what to tell ya. I can assume that a 140 XCMH is a pretty big SOB though. I ordered a 120/100/18 for a buddy of mine. Here's a pic of it beside a 120/100/18 TMII. Not a good pic, but it was considerably LARGER and ALOT heavier too.
  • XR650L_Dave
Posted 12 May 2011 - 06:04 PM
kenshaw720 said:
Well, sure, 2 years later they"re in stock!
These work pretty damn good.
Dave
  • kenshaw720
Posted 12 May 2011 - 06:22 PM
Dave
Patience pays off:smirk:
  • gravitas
Posted 21 June 2011 - 01:35 AM
The kenda TMII is pretty small for a 120/100 IMO
  • ROMAD
Posted 22 June 2011 - 01:51 PM
I have a 120 XCMH and its the largest 120 class tire I have seen. Every 120 I compare it to is noticeably smaller - not saying I have compared them to every tire but all my buddies have 120s from various manufacturers and none of them are close.
  • SloDon
Posted 22 June 2011 - 08:28 PM
I have been wanting to try these.....so mounted a set yesterday....it is wide, the 120 measured 130mm (measured by laying the unmounted tire flat and put a straight edge across the top) so fit was no problem.
Been raining so no ride on it yet......
