Starting in Neutral
2 replies to this topic
  • buzzfin
Posted July 06, 2009 - 08:43 AM
Why is my '09 easier to start in neutral, especially when hot? Starting in gear with the clutch pulled always takes many kicks. Is this common or is it possible I have an adjustment issue with my clutch? Seems to be in perfect adjustment while riding.
  • meyermetal
Posted July 06, 2009 - 08:49 AM
there is no drag from the trans while in N...when in gear the clutch will always put a little drag on the crank even though you pull the lever in
Posted July 06, 2009 - 10:44 AM
It's quite common, even normal, partly for the reasons just given, and also partly because the timing is slightly more advanced at idle in neutral than when in gear.
  • Hot  50 replies
  • 0 replies
  • Hot  28 replies
