Sprocket size ?
10 replies to this topic
  • slygary
Posted July 05, 2009 - 04:08 AM
I just got a brand new 09 wr450, what rear spocket size will help with performance ?, bottom end pull and etc.
  • Krannie McKranface
Posted July 05, 2009 - 04:55 PM
Uncork and re-jet first.
  • slygary
Posted July 06, 2009 - 02:26 AM
Yeah i have done all the so called free mods. I just want to find out what rear sprockets other people have played around with.
  • ww44wrf450f
Posted July 06, 2009 - 08:41 AM
Well, personaly I haven,t played with sprocket size yet, but after all the free mod,s a slip-0n DR.D was my best upgrade power-wise, 4th gear gas, 5th gear and a modest pull on the handle bars and it's up! :worthy:
You could drop a tooth on the front sprocket and try that as a starting point!
The 09 header is small, go get a DR.D full s.s. system. Check e-bay out for a good deal - $400 and under if you can find one in an auction!
A cheaper route would be a used yz system, $100.
  • SJMC_DON
Posted July 06, 2009 - 11:39 AM
That will be way too low, trust me.... been there done that.
If your convinced you want a little more bottom via gearing, I would start with a 49 or 48.... buy cheaper steel ones:thumbsup:
  • 123BigcoopDawg576
Posted July 06, 2009 - 11:50 AM
isnt stock a 50 on the rear?
  • SJMC_DON
Posted July 06, 2009 - 12:10 PM
Yeah... I partied kinda hard on the 4th am I am still focused on my DS gearing ideas.:worthy:
51T or 52T...
  • 123BigcoopDawg576
Posted July 06, 2009 - 01:45 PM
Yeah... I partied kinda hard on the 4th am I am still focused on my DS gearing ideas.:banana:
51T or 52T...
Its all good...on my 08, the best "do it all" gearing (that I have found) is 14/50
The reason I say that, is I can cruse at 50, blast 90+ and single track :worthy:
  • SJMC_DON
Posted July 06, 2009 - 02:13 PM
Thats what I am running as well but considering dropping a tooth on the rear... I don't know, maybe going to a 51 :banana:
  • chevytrkn1
Posted July 06, 2009 - 04:51 PM
Im running 13 52 on my 07, added 2 to the rear. Do a ton of tight technical riding and its helped alot
  • ww44wrf450f
Posted July 06, 2009 - 05:54 PM
There is always a sacrafice when it comes to spending a buck, you can cut the baffles out of your stocker-- or a used yz full system or a dr.d is the way to go ---- period --- and play with your jets.:banana: :worthy:
