What lubes and greases do you use?
5 replies to this topic
  • Andrejs2112
Posted July 05, 2009 - 03:49 AM
I was wondering what kind of lubes I'd need to start maintenance on my 03 Wr 450. The manual has the types listed, but I have never heard of them by the names used. What do I need to get when I go to the automotive store to buy lube? What is used where? NOT ENGINE OIlL.
Thanks,
AR
  • 02WR426Cali
Posted July 05, 2009 - 08:16 PM
I have used disc brake hi temp bearing grease for all of the bearings in the chassis and wheels and it works fine. I know have some waterproof belray grease for this and like it better. For cables you could probably just use some type of lube spray from an auto parts store, can't think of any names. Anti seize or white lithium grease for bolts and such. White lithium works for anything the manual says "soap based" or something to that affect. It will probably work on most anything really.
  • Andrejs2112
Posted July 06, 2009 - 02:59 AM
Thank you. I happen to have that in my garage now. Just wasn't sure.
  • WR450FGreg
Posted July 06, 2009 - 11:31 AM
For the past 30 years I've always used plain old waterproof marine grease for any joint requiring grease on any dirt or road bike I've owned.
It's available at any auto shop.
It's worked flawlessly in that time and is cheaper than anything you'll buy in a bike shop.
Cables: I use a cable luber and WD40 first to clean the cable out, then chain lube after that for lubrication.
Pivot points (footpegs etc.): I use the grease here too, or if i don't have time to pull them apart to grease then I use chain lube spray as best I can, working the joint to get it right in as I spray.
Greg
  • nitronaf
Posted July 09, 2009 - 07:17 AM
Greg
What chain lube do you use greg? :worthy:
  • WR450FGreg
Posted July 10, 2009 - 02:03 AM
In the past I have always used one of the chain waxes, eg. Maxima.
I recently bought a can of Silkolene Chain Gel and might give it a try for a while. I like the way it leaves that white film all over your chain, looks like a new chain every time you spray it on!
Greg
