clutch cable question
4 replies to this topic
  • Just_a_trail_rider
Posted July 04, 2009 - 07:45 PM
I have a 05 wr450. I am looking to get more adjustability of my clutch cable tension. It seems that I have the adjustments on the cable set to allow for maximum slack. I also have the quick adjust knob set for max slack.
I have put on taller and wider bars and need to gain back the adjustability for when I am riding the cluch hard and need to add a little slack to a hot clutch.
How do I know how much longer of a cable to order? Is there a way to measure what I will need?
  • Krannie McKranface
Posted July 04, 2009 - 09:15 PM
IMHO, you should be fine with the stock cable, if it is routed correctly. I have a 1.45 rise clamps and CR High bars with clutch cable problem .
The cable length should have nothing to do with free play adjustments.
Posted July 05, 2009 - 07:50 AM
Do you still have it routed along the right side, beneath the CDI , along the frame, under the carb and then over to the left side? I was thinking of trying to route it along the left side instead.
I definitely need to get more free play adjustment out of the cable. I just fried another clutch. Sure... I was working the lever really hard, and I had to given where I was riding. But to start the day with everything adjusted all the way out and still only 1/2 inch of free play is not right.
btw... I'm trying honda plates and will also drill my clutch basket for more oil flow.
Posted July 05, 2009 - 08:39 AM
- all cables routed on left side against/under backbone
- new clutch plates and basket
Posted July 05, 2009 - 09:57 PM
Thanks. I'm going to try rerouting the cable.
