Garmin E-Trex GPS
8 replies to this topic
  • fastmonstr
Posted September 15, 2002 - 05:02 PM
I just got a E-Trex Legend. Has anybody had any success mounting one to you thumper???
  • Tim_in_WA
Posted September 16, 2002 - 01:33 AM
Check out cycoactive.com for mounting solutions. They're experts when it comes to GPS and motorcycles.
  • kris_mobley
Posted September 16, 2002 - 02:15 AM
I am using Cycoactive's mounting kit for my E-trex. The remote battery pack is effective. Longer battery life ane helps reduce vibration problems. It is made somewhat cheaply, but works.
  • PumpkinHumper
Posted September 16, 2002 - 03:28 AM
Check out a-loop
I was just in there site yesterday. They have a lot of stuff for gps. Including a "hardning" procedure that helps solidify the circut boards against the vibration and pounding that a bike can deliver.
[ September 16, 2002, 06:31 AM: Message edited by: yzman400 ]
  • wrong
Posted September 16, 2002 - 03:53 AM
Best mount is the RAM ball mount. 2 Garmin etrex's, 2 RAM ball mounts-0 problems
  • PumpkinHumper
Posted September 16, 2002 - 06:17 AM
Oops. A-loop is no more. Just surfin there site. They have shut down the shop.
  • mikeolichney
Posted September 17, 2002 - 09:57 PM
If you have fatbars, get a barpad and cut a spot for your GPS. Zip tie it in (using the mount if it fits well). You can change back to a normal barpad easily.
Try not to smash your helmet into the GPS on your next getoff.
  • neWRiver
Posted September 19, 2002 - 08:11 AM
RAM mounts are very good and cycoactive is a good site that offers just about everything you can get for offroading with your GPS.
I had a Legend and liked it alot. One suggestion, though. The cradle on the RAM mount holds the unit pretty securely, but do make sure you attach a backup strap or zip-tie or something in case it falls out. I've had a fair number of pretty rough getoffs and the unit never budged,... well except once. :)
I have a Garmin GPS V now (great unit, but expensive). :D
  • fastmonstr
Posted September 19, 2002 - 10:46 AM
The RAM mount is less expensive of the 2. The main thing I do not like about it is that it appears to stick about 2-3 inches above the handlebars.
It looks like it could get knocked around quite a bit.
