03 WR450 loses power after jump or big bump
5 replies to this topic
  • law_boy
Posted July 02, 2009 - 10:28 PM
My O3 WR450 loses power for a couple seconds and almost dies after a jump or a big bump. Then it returns to normal and just keeps going like nothing happened. What would cause this? I have no idea where to start. The bike only has about 1400 miles on it and it everything seems to be in good shape. Any ideas?
Thanks.
  • Krannie McKranface
Posted July 03, 2009 - 06:18 AM
Thanks.
From my experience this is from fuel cavitation, or fuel starvation.
Have you re-jetted the carb from stock? If not, that is something you need to do.
  • MaddogYZ
Posted July 03, 2009 - 03:57 PM
Try landing with the throttle on and see if still bogs out. Check your float hieght.
  • law_boy
Posted July 03, 2009 - 09:05 PM
I did the jetting myself and it worked ok but then I had it in to the dealer for the woodruff key upgrade/repair issue and they did the jetting for me. Worked so much better. This was back in 04. Never had a problem since then.
Now that I think about it, I don't know if I have the throttle on when I land or not. I don't really jump my bike much - I have just noticed this happen on the few occasions when I happen to come across a nice berm or something that begs for a little launch, like those drainage cuts on fire roads, etc. Also, occassionally a big enough bump will do it. Interestingly, I can ride whoops and have no problem but if I launch off one and land hard enough it starts to die out sometimes.
I'll check the posts on float height to find out what that's all about.
  • William1
Posted July 04, 2009 - 02:28 AM
+2 on float height
  • graazzy
Posted July 05, 2009 - 12:07 AM
I had the same prob .I opened the drain bolt on the bottom of the carby and it went away . I assume there must have been water in the bowl.
