Stripped threads!!!
5 replies to this topic
  • abou_l_simm
Posted July 02, 2009 - 12:26 AM
How Bad is it if you over-torque the 2 screws that hold the front wheel axle to the Fork tube flanges.
I was using an old needle type torque wrench trying to get the 20 ft-lb recommneded in the manual...but I think I overdid it.
What's the contingency if I stripped the threads on these?
http://shop.thumpert...007&model=12915 --> bolt #52
  • ajeb
Posted July 02, 2009 - 03:16 AM
If you have stripped the threads they can be easily repaired
with either the heli-coil or time-sert thread repair systems.
The time-sert is the prefered option.
  • rparobi
Posted July 02, 2009 - 03:51 AM
I'm pretty sure they should be tightened to 20 Nm not 20 ft/lb quite a significant difference in torque
Posted July 02, 2009 - 06:44 AM
Right. The spec is 23Nm or 17 ft/lb.
You will have to have these bolt holes Heli-Coiled, or red-neck it by drilling them through and using longer bolts with nuts on them. They're important.
  • Aka.Goose
Posted July 02, 2009 - 04:50 PM
Could you just tap it one size up to use a bolt one mm thicker?
Posted July 02, 2009 - 05:15 PM
Doing that tends to weaken the clamping area of the lug. It's best to stay with a Heli-Coil, and insert it from the threaded side so the top side is not drilled larger.
