Weird shifting problem... No neutral YZ450F
3 replies to this topic
  • writebrian
Posted July 01, 2009 - 10:02 PM
I have a 2006 YZ450F with a weird problem. I can't shift it into neutral while its running. I've tried with my boots on and using my hand and no go. However if the bike is not running I can shift in and out with NO problems. Are there any oil pressure related things that can make me miss neutral while it's running.
Any ideas?
  • ajeb
Posted July 02, 2009 - 03:13 AM
Your shifting issue stems from the clutch.
The clutch is not disengaging correctly, causing clutch drag.
Providing your clutch is correctly adjusted.
Inspect your clutch assembly for excessive wear and/or distortion.
Posted July 02, 2009 - 07:46 AM
There's nothing weird about this problem:
  • Schock
Posted July 02, 2009 - 10:29 AM
Yes, I had that problem so I changed the clutch boss, because that little lock inside the clutch broke and scratched it.
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
Need help by Goforaride
  • Hot  68 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
  • 9 replies
