Float Needle Valves
13 replies to this topic
  • Frank Grimes
Posted June 29, 2009 - 08:26 AM
I think the needle valve on my 426 is bad is there a source where I can buy just the needle? There is a kit but it is like $56 and has a bunch of parts I don't think I need.
Posted June 29, 2009 - 10:50 AM
The needle seat from '03 onward is not serviced, and so the needle for those carbs is sold by itself. I do not know if an '03 needle will work in a 426 carb, but you might have a look at one. PN= 4MX-14392-00-00
  • PATHPOUNDER
Posted June 29, 2009 - 11:20 AM
Why do you think the needle is bad..?? I just checked mine on an 01 426...It was leaking fuel...I replaced the o ring..its fine now..
  • laserracer
Posted June 29, 2009 - 11:43 AM
same as above had fuel leak replaced O ring all good now:ride:
Posted June 29, 2009 - 12:39 PM
So the 450 O-rings did actually fix your 426?
  • Frank Grimes
Posted June 29, 2009 - 07:27 PM
I assumed it was the float needle since the carb fills with so much fuel and drains a ton of it out.
I forgot to mention mine is a 2002 YZ426
Was this similar to your fuel problems?
What O-ring did you guys use?
  • Ray450
Posted June 29, 2009 - 08:00 PM
Sorry if I'm stating the obvious and you have already checked, but make sure your floats are adjusted correctly. I've found that after several years, float settings tend to drift a little, almost always higher. All the whoops and jump landings eventually take a toll on that tiny tab of metal.
  • laserracer
Posted June 29, 2009 - 08:37 PM
yep mine is a 2002 was leaking excess fuel, O ring was stuffed it looked more like a plastic washer than a rubber O ring got mine for free from a specialist O ring and gasket company here in nz
  • PATHPOUNDER
Posted June 30, 2009 - 03:59 PM
Dont know yet....i just ordered them today...these were for the inlet...
I replaced the needle valve o ring last week and it stopped the leaking from the overflow tube...Ill post results when I get the 450 0 rings in for the inlet..
  • PATHPOUNDER
Posted June 30, 2009 - 04:06 PM
More than likely its the o ring around the needle valve....Yamaha wont sell them, they want you to buy the needle valve and seat complete for 75.00..
I bought mine from Sudco....Problem there is they have a 25.00 minimum order...If one is leaking...more will soon...Go to their website and look at their schematic...Pick out several different o rings....get the 3 at the inlet, those will go soon..they did for me..
Posted June 30, 2009 - 07:06 PM
An alternative might be to buy a complete gasket kit for a CRF from Honda for $18 or so. The PN for an '02 is 16010-MEB-671
  • Frank Grimes
Posted July 01, 2009 - 06:30 AM
Are they the same? Have you tried it? If so that would be awesome.
Does anyone have a part number for the O-ring or the dimensions?
  • Frank Grimes
Posted July 22, 2009 - 05:43 PM
Can I just use a hardware store O-Ring? If so what size?
  • PATHPOUNDER
Posted July 23, 2009 - 04:23 PM
I couldnt get any to work...So I ordered it from sudco..
  • Hot  50 replies
  • Hot  47 replies
  • On Yesterday, 06:20 PM
Motocross
  • Hot  491 replies
