Need help with starter
3 replies to this topic
  • cyclebender
Posted June 28, 2009 - 02:03 PM
Feel like a real novice here. Have a 2003 WR450. Replaced the brushes in my starter. I thought I put it back to gather the way I took it apart. After reinstalling the starter, it won't engage the drive gear. Removed the drive gear cover, and found the started was spining in the wrong direction I know if you reverse the polarity, you can reverse the direction of the motor. I checked the leads from the starter relay, they appear to be correct. Any idea what I did wrong. Any help is greatly appreaciated.
  • fwdtomco
Posted June 28, 2009 - 06:54 PM
you have the case that the permanent magnets are housed in ( armature rotates in ) installed backwards between the end caps of the starter . Check out the starter breakdown in the manual , there is a picture that clearly shows the groove on one end of the case and the direction that it should be installed between the starter end caps.
  • cyclebender
Posted June 29, 2009 - 02:02 AM
Thanks for your input. What a dummy I am. Will pull the starter and switch the coil housing.
  • DrBosa
Posted June 30, 2009 - 11:15 PM
Did you mark stator and end caps with a filt pen so you are sure you put the part back together the exact same way? Check this thread:
http://www.thumperta...t=729868&page=3
