a valve question...
9 replies to this topic
  • bendover932
Posted June 28, 2009 - 07:32 AM
ive spent the morning searching/reading but havent found the answer...could an out of spec valve/s cause an 07 yz450 to stall abruptly while idling as if you hit the kill switch?.....ive got a strange situation going on after some jetting changes/r&d power kit install...which i reverved and am now back to the same jets/parts prior to the problem..and its still doing it....on the track it seemed ok until you come to a corner and it stalled i restart and while idling after maybe 5 seconds or so its starts to miss...almost as if you just stabbed the kill switch for a second...it might do it once or twice....and die....the bike starts up right back up first kick usually but no more than 2-3 kicks and sometimes it might backfire other times not...if you try and twist the throttle slowly it dies...but sometimes if you can get it past idle and keep the idle at 3000rpms or above it will stay running...holding it at a steady rpm there is slight poping ..like brrrrrrrrrr pop brrrrrrrrrrrrrrrrrrrrrpop pop.brrrrrrrrrrrrrrrr..not loud like a loud backfire more like a miss..not sure if thats normal since ive never held it at a higher idle before...ive gone over everything i know to check....cleaned the carb 3 times ...checked all connections ...checked timing and its spot on...need to run out to get some feeler gauges to check clearances...could it be the tps all the search results i read on problems with that dont sound like my problem...but im running out of ideas.......anyone have any ideas of other things to check?
  • walent215
Posted June 28, 2009 - 10:57 AM
i had my fuel screw fall out before and the symptoms were very similar to what your describing.
Posted June 28, 2009 - 11:35 AM
Your problem sounds more like a carb issue (lean) than anything else. The suggestion of a fuel screw missing is along the right lines, and should be checked, along with a thorough inspection of the carb. You are missing something basic.
  • bendover932
Posted June 28, 2009 - 12:43 PM
that's what I was thinking that it had to be a carb issue since it all started after The changes... But I've had the carb off and apart 4times the fuel screw is definately in there along with the spring washer and o ring.....as I was turning it in 1/4 turn increments from fully seated till It was out of threads...triple checked clamps on both sides of carb ....sprayed everything with carb cleaner while running...no rpm raise....so that's why I started looking elsewhere.... What else shoul I look at in respect to the carb?
  • walent215
Posted June 28, 2009 - 01:51 PM
check hot start,the plastic fitting could have a crack or something in it,or partially stuck open.
  • bendover932
Posted June 28, 2009 - 02:05 PM
No visual cracks in the plastic hot start adapter but pulled it off and put a rubber tip air nozzle on one side and finger on other pressurized it and didn't hear air...dunked in water no bubbles....
  • walent215
Posted June 28, 2009 - 03:30 PM
the slide can abe assembled wrong very easily when going back together also.the plate is easily inverted because of the way it looks.this has also been known to cause problems like this.
  • bendover932
Posted June 28, 2009 - 04:51 PM
i actually didnt take the slide out at all just opened the top and swapped needles and then reversed the swap
  • walent215
Posted June 28, 2009 - 05:39 PM
is it happening when it is cold and also after being warmed up?i once had a coil go bad on an 03 yz 450 and it was fine cold and then acted up once it got warm.
  • bendover932
Posted June 28, 2009 - 06:04 PM
It did it at the track the first time I rode after the mods... And again when cold on the stand in the garage later the same day...and every time Ive start it since
  • Hot  113 replies
  • Hot  50 replies
  • 10 replies
  • Hot  38 replies
  • 5 replies
