having hard time sealing stator cover gasket
2 replies to this topic
  • jhmotard
Posted June 27, 2009 - 06:54 AM
i'm leaking oil at the bottom of the stator cover, replaced with a oem paper gasket once already. cover or sidecase is not cracked, gasket surfaces were clean and dry before reinstallation.
looking for a trick to get this to seal right.....maybe rtv silicone between the surfaces?
  • jhmotard
Posted June 27, 2009 - 10:05 AM
anyone?
  • William1
Posted June 27, 2009 - 10:08 AM
A fresh gasket should not leak. Is the case or cover gouged? Youcan use a thin coat of something like YamaBond or ThreeBond, but you should not need it. You should try to figure out why it leaks more than just stopping the leak.
