rumplefester said:
OK, that explains the tire profile, however if your sag is set up correctly, the rim/tire profile is irrelevant IMO. I still don't understand why the rim size difference.
Just trying to learn...
- KeVin
what he's saying if i understand correctly is that the outside diameter of the two tires are the same. so the 18'' rim gives that tire a deeper sidewall, which in turn allows for more sidewall flex.
it is like putting low profile tires on a car. you will hook up better and corner a little better, but you will feel bumps much easier.
at leaste that's how i understand it.
